Parking Mode not being triggered
My main reason for having a dashcam in Parking Mode is to capture any incidents where someone approaches the car to vandalize it, like putting a scratch on it. Of course a collision will be recorded due to the impact.
I do realize that. Looking for software that can go thru a video and search for moments in the whole recorded video for "changes". This can include a car driving by, someone walking by, etc. This saves you the time it takes to go thru the whole video yourself.
I think there is something unusual about the VS1 in AED. My A229 Plus triggers with motion (no vibration, impact or G-sensor needed). (I have videos in AED where I'm walking towards my car from far away. What makes the VS1 different?
VS1 does have a much smaller body. Are certain things excluded like certain components in the VS1 due to its small size versus say the A229 Plus?
Is the VS1 FOV for the motion detection very narrow compared to the A229 Plus? In my test, if you stand directly in front of the cam, even from 6-7 feet away, it triggers the AED to record. Stand to the side, no. What this tells me is that the VS1 FOV for motion detection is very narrow. The cam's 140* FOV is not the motion detection FOV. I can't measure but it could even be as narrow as 45* to 50*.
Reviewers of this cam should test for this. Too bad we don't have an equivalent (I know, niche market) Consumer Reports testing on these dashcams. Ex. Buyer beware, the VS1 in AED only works within a very narrow FOV and mostly does not trigger or work for motion detection only. Some sort of impact or vibration is required to trigger motion (except for that narrow FOV where it might work).
Since discovering sadly, that the AED Parking Mode is almost useless in my copy of the VS1, I am trying Time-Lapse. How many fps would you recommend to at least get a clear image of someone when I scroll thru the video quickly to review it?
How many fps is Low-Bitrate and AED mode?
Everything you need to know about parking mode - Viofo website
"Through numerous tests we've conducted across different VIOFO models and also based on users' feedback, we would recommend you to use Time Lapse Recording which is the most stable one and consumes much less power." - From Viofo link above.
Auto Event Detection with Motion
File Size (MB) 188
Avg Watts 6.68
Time Lapse Recording at 10fps
File Size (MB) 152
Avg Watts 5.99
Low Bitrate Recording
File Size (MB) 128
Avg Watts 6.49
*Data source: A229 Pro 3CH
I have a volt/amp meter hooked up inline via usb to check stuff.
I'm seeing most, .8 amps at 5.1 volts, so say 4 watts FOR 2 VS-1's in normal recording.
I was seeing, if I recall, 50 mb files for one minute on low bitrate. I'll check again at some point.
I have 2 such meters. I was trying to find out how many FPS would offer a clear view in one frame (like when I fast forward thru a video clip and then stop at some motion). I Googled it (A.I.) and it seems 5fps is more than enough to see a face clearly.
I tested 1fps and now testing 5fps. If 5fps is good enough I won't need 10fps. Interesting that VIOFO recommends Timelapse as the best Parking Mode option to use for reliability and energy efficiency (stable and uses much less power).
This can't be right? I know Auto Event Detection on my A229 Plus 3-Channel can be triggered by motion even if it's a car crossing the camera's FOV or me walking toward the car from a distance. And some users were advised in the past to set the motion sensitivity to Low on Viofo cams to avoid having leaves blown by the wind triggering the motion sensor. Does the VS1 auto event detection (motion detection) work differently from the other Viofo cams? I do have the VS1 G-Sensor set to Low just like on my A229 Plus 3-Channel.
@viofo
I heard back from Viofo Support.
How the VS1 Auto Event Detection Works
The VS1 uses a G-sensor-based motion detection for Auto Event Detection in parking mode. This means it detects:
- Physical vibrations and impacts are transmitted through the vehicle itself
- Direct contact or movement of the camera unit
This is why running your hand across the VS1 directly triggers a recording — you're creating a physical vibration on the sensor itself.
Why It's Not Detecting Movement Through the Windows
- 🔴 Visual movement alone does not trigger Auto Event Detection — a person walking past the windshield creates no physical vibration on the camera
- 🔴 The sensor is not a visual/PIR motion detector — it cannot detect movement it "sees" through the glass
It seems replied by AI mistakenly. Normally, the camera will be triggered when there is a moving event in its view range. Your camera may be defective if it works like this. We will test for confirmation.
It only triggered when I was 6 feet from the camera and right in front of the camera from 6-7 feet away and sometimes just to the right edge but not repeatable. If buyers knew the AED in the VS1 almost never works, people might reconsider buying the VS1 to use in AED in Parking Mode. A disappointment and maybe even false advertisement.
@viofo
Let me know what your test results show. Especially the way I have it set up in the middle of the car, with VS1 covering the rear windshield and part of the 2 rear passenger windows.
PS. You mean the Viofo email was done by A.I.?
@viofo
Our engineer will release a special firmware to improve the sensitvity for you to test. All messages are replied by human beings. That message you received was sent by my new colleague who searched with AI mistakenly.
I just tried the same Parking Mode settings on a second Viofo VS1 and had the same results as the first one inside the car. Plan to maybe give this second VS1 one to a family member. Walking past the rear windshield, standing behind the rear windshield, etc. does NOT trigger AED to record.
Still waiting for your engineers to test and the results.
There will be a customized firmware for you to test, please wait for several days and contact with my colleague via ticket you have opened for it.
I have received the link to a new special firmware for the VS1. It is supposed to be more sensitive to motion. The firmware was created by Viofo to see if it will resolve the VS1 issue where in Auto-Event Detection (Parking Mode Option) the camera dose not record where there is motion within its FOV.
For the past several weeks I have been using Timelapse at 5 second intervals. I am really enjoying Timelapse. It's reliable, energy efficient on the external battery and is aesy to fast forward thru each captured video file. Only problem is it's still time consuming.
That is where the AED Parking Mode comes in handy. You only want the VS1 to capture video when there is motion detected. Then when reviewing videos captured in Parking Mode, each video will be on your memory card ONLY when it's worth recording, motion triggered your camera to start recording.
I plan to test the new firmware and thanks to @viofo for taking the time and putting in the effort to create the new firmware. I have a question for @viofo and the folks who do the testing and review of Viofo dashcams on this forum. Would Viofo allow these well known dashcam testers to test the new firmware in their lab like environments? And would any dashcam testers be interested in testing the new firmware (will have to get permission from Viofo first)? Thanks.
No Viofo reviewers remotely interested in testing an improved function in Parking Mode AED?
It's not for you then. But those who test features of dashcams may be interested.
I have been using the VS1 in time-lapse mode (5 fps) for Parking Mode and quite happy with it. At this frame-rate I can fast-forward thru a Parking Mode video quickly, in under 20 seconds. I only stop the video when I see something.
Time-lapse is the Viofo recommended reliable Parking Mode. Energy efficient too.
That is why you haven't heard back from me. Happy with Time-lapse in Parking mode.
Not going to use the unreliable Auto-Event Detection especially on the VS1 which did not work. Haven't tried the new FW yet but may test it on my second VS1.
A final note on the VS1. This is a great little dashcam if you want an unobstrusive dashcam. Very responsive to voice commands. Hoping Viofo will provide it with a wider lens in a future model but for a front windshield dashcam it is good enough. Police and insurance in Ontario, Canada and probably elsewhere are mostly interested in how YOU are driving to assign fault. You the driver is responsible for what is happening in front of you on the road. The cost for the VS1 is very low.
