Stop right there.
False & Misleading Statements.
Do not pass go.
Do not collect $200.
I didn’t even give you any rope this time, and you’ve already tied your own noose.
This statement is going to confuse your customers.
This may lead purchases, that do not work for their application.
Upset / angry customers usually turn to social media to begging a scorched earth campaign on BBMC’s reputation.
OBD Ports are divided into two main categories.
OBD 1 (1981-1995)
OBD 2 (1996-current)
Some 1994 & 1995 vehicles have an OBD2 DLC (diagnostic link connector) aka “ OBD port”.
However they are not fully functional OBD2 compliant.
Starting in 2005-2008 CANBUS was added to further enhance / complicate the protocol.
You can think of CANBUS as “OBD2.5”.
Within these two main categories there are sub categories for vehicle type;
Passenger Car & Light Pickup (usually under 13,999lbs. GVWR) think Ford F-350 / Chevy 3500, and smaller.
Medium Duty & Heavy Duty Trucks & Commercial Vehicles, (usually over 14,000lbs. GVWR).
The second category of Medium Duty & Heavy Duty Trucks & Commercial Vehicles are not bound to the same ODB2 Port specifications, (different pins do different things).
Do you see where I’m going this this?
EV’s have been granted exemption from full OBD2 compliance for Passenger Car & Light Pickups.
Within these two categories, there are more sub categories for different countries / regions of the world.
There ain’t no “ignition pin” in any OBD2 Port.
All current OBD2 Power Cables from dash cam manufacturers use a mishmash different logic to “try” to get proper function of parking mode enable / disable.
All OBD2 Power Cables I’ve tested from VIOFO, Vantrue, 70mai, Vueroid, use a combination of, (System Voltage, Built-in G-Sensor, and Timers).
None of them are 100% reliable.
The most reliable OBD2 Power Cable I’ve seen is the one from IROAD.
That’s why Ben made a custom OBD2 Power Cable for VIOFO cameras using an HK4, and IROAD OBD2 Power Cable.
“3-Wire Spliced Output” no longer needed.
VIOFO just made this a whole lot easier.
For the first time ever VIOFO now offers a (Type-C to Type-C Power Cable) with necessary pins to enable / disable parking mode with Ignition / ACC based signal for 100% reliable operation.
However, this cable is only compatible with BP60, (included in BP60 Box).
Joseph sent me my first VIOFO dash cam for test & review back in September 2020, (A129 Plus Duo).
I’ve been meaning to make the drive up, and thank him personally for putting me in the “dash cam review game”.
Maybe we could have lunch, and geek out over all these details.
Actually, I’ll be at SEMA Las Vegas 2026 in 3 weeks, did you guys make any changes in attendance?
-Chuck
