Nice simple question I hope.
Does this dash cam have parking mode?
For Dashcam products that have a Novatek chipset, the Novatek SDK / Hardware doesn't currently have pre-buffer as an option to use, so motion detection is a start/stop operation. Moments leading up to the trigger will be lost. (no pre-buffer)
Best option is to let the system record an extra hour or two via hard wire kit that supports timed power (such as the Vico Power Plus)
Recording 24/7 non-stop would be too punishing on the memory card and hardware though.
It has start stop basic motion detection
I doesn't have pre-buffered motion detection.
So, Head Gardener is saying that in his experience the A119 motion detect does not "start stop" even without pre-buffering. He says it simply starts but does not stop when the motion stops. Perhaps it is so sensitive that it picks up a fly at 100yds and will only switch itself off in a dark garage.
If this is correct, Viofo should either remove the claim from the product details or fix the motion detect.
during my tests for overnight recording with a "motion detection" on from 11pm through 6am I had under 1 hour recording.
And during a 10pm till 08am test using MD I had 10 hrs solid, minute after minute, collection of 3 minute files to look thru....(32 Gbs worth)
I will say that out of the thousands of A119 cams out there, mine is the only one that is Hypersensitive!
in what sort of environment, got some sample footage?
also 10 hours won't be fitting on 32gb, you'd only have the last few hours if it was going all the time
