Hyundai kona 2024
- Nov 29, 2016
- bristol uk
- United Kingdom
- thinkware t700 lte
shoud i use my iphone APN PASSWORD for hotspot connection. HELP IM GOING MAD
If the APN you are referring to is Access Point Name of your cellular network, then you are completely way off target.shoud i use my iphone APN PASSWORD for hotspot connection. HELP IM GOING MAD
Not sure if your personal hotspot is referring to the mobile wifi router or your iPhone but if it's your mobile wifi router, it's likely you'll have to disable 5Ghz connection on the router as Edwin had already confirmed in this post it will only connect of 2.4Ghz. I too was prompted to check for password even though it is correct when I attempted to connect to my dual band router but I didn't bother to change it to confirm his finding as it was my home router. It is likely due to the same issue as it attempted to connect to 5Ghz.View attachment 34664 quick update f800 pro will connect to hotpsot but i have to turn my personal hotspot on my iphone to connect every time,
surley that cant be right . YOU SEE I KEEP MY PERSONAL HOTSPOT ON ALL THE TIME
FOR WHEN IM OUT AND ABOUT and every thing else connects ipart from the f800 pro ???
HELP PLEASE
i this thread( https://dashcamtalk.com/forum/threads/personal-hotspot-auto-connect.31533/page-2#post-374462 ) it says
For my phone I used my exact hot spot name and password.
For my car’s hot spot I had to change my hotspots settings to 2.4Ghz since 5Ghz is not supported.
How do I set my hotspot to 2.4ghz on iPhone or Thinkware appPersonal hotspot uses cellular service to provide a hotspot not wifi. I think hotspot is at 2.4Ghz.
All I want to do is connect my iPhone to the F800 Pro via my personal hotspotWhat are you aiming to achieve? You can't change the Ghz your phone broadcasts at.
Your Apple iPhone's aren't connecting because your hotspot isn't available for the Thinkware Dash Cam to connect to. Your camera cannot connect to a signal that is not there to connect to.
It connects immediately without you having to touch your phone or camera after getting in your car for the first time that day?My iPhone connects to my F800Pro just fine via Hotspot.
That’s my point and what I was getting at..yes my iphone connects as well just not automatically. and at the moment it wet and very cold outside . so it can wait,
M | Hotspot not connecting in App | F800 / F800 PRO | 20 | |
D | WiFi/Hotspot Connection | F800 / F800 PRO | 1 | |
R | Hotspot connection | F800 / F800 PRO | 3 | |
V | Thinkware f800pro hotspot connection | F800 / F800 PRO | 0 | |
thinkware f800 pro personal hotspot | F800 / F800 PRO | 48 |
