The 360 video i use the K2S system as side cameras, it have smaller cameras than other remote ( rear ) or similar dual remote camera systems i have seen / tested.
https://dashcamtalk.com/forum/threads/k2s-received.37896/
The K2S actually also came with a OBD adapter for powering it, as you can see in the pictures in my thread about it.
It is a bit hard to recommend something i have not tested, or heard about from others, but that dont mean its garbage it could still be a OK system.
I have to excuse myself here, yesterday when i clicked at your link i was sent to Amazon UK and saw some 2 channel system, right now i use my VPN to fake i am American and see the real deal.
And for sure not something i have seen before, looks or the brand name.
Now testing other cameras with a interior camera, you can get a glimpse of what is going on outside by that camera, but it is like looking thru a small window and also depending on how good the system are in exposure the outside might be overexposed.
I have a few videos demonstrating performance of interior cameras on other model systems.
Here interior just a short glimpse in the middle of the video.
Here wearing my 4 of July T-shirt.
To me that is not good enough situational awareness / documentation. that is just what go on in the car.
There are also a longer thread where we talk side cameras.
https://dashcamtalk.com/forum/threa...a-side-view-dashcam-for-your-car-doors.12675/
It is my understanding that the systems powered thru a OBD adapter are then also able to do parkig guard.
In the conventional systems with 3 wire hard wire kit, then yes the ACC are sort of just the trigger wire to know if the care are on or not, you can also tap in other places than the fuse box, then you just need a inline fuse.
In your case with no ACC fuse in the box, i would assume the cigarette lighter plug are ACC and the radio / entertainment center ASO
How parking mode are handled are a bit different, aside for the modes them self.
The ones that rely on a buffer, for the most 5 - 10 seconds they come on and then turn off again 10 - 20 seconds later.
My favorite are segment handling instead, and the way street guardian do it as they save 2 of them from each camera.
So most will just save the current segment being made ( 1-2-3-5-10 minutes however you have chosen ) and that is just fine,,,,, IF A: you are not right at the end of the current file by chance, CUZ then you will not get much of what happen after ( that could be offender reversing and running ) - B : if you by chance are right at the start of the current segment, CUZ then you will not have much of leading up to the event, which are less of a issue i think.
BUT ! Street guardian do 2 files, so say you are using 3 minutes for segment size.
If you are 1 minute into the current segment, then it and the previous one will be saved and you will have 4 minutes before trigger and 2 minutes after.
Alternative say you are 2 minutes into the current segment, then current one will be saved and the following one and you will have 2 minuted from before event and 4 minutes after the event
Of course this are more footage indeed, but in my testing i found it to be no issue, but it might be if you are silly enough to have G-sensor on while driving, CUZ then potholes and what ever the god damn state
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
do not fix with all the tax money you give them, will eat up on the assigned memory space for events.
But not having such slutter / garbage footage in the event folder and you will have actual events there going back months as the files in the event / RO ( read Only ) folder are safe from being deleted when the card are full.
I personally use the manual event button when i see something i want to save while driving, i would do the same if i got into a small fender bender.
As i use low bitrate always record while park, everything are recorded, so in general i do not need any form of events to be saved, but still i have G-sensor on so if something actually happen at least it will work as a flag to look for.
Same using the manual event button as it usually dont take me weeks to retrive footage, anything that are outside of the saved / locked event will also still be there, i dont drive mych, i think like 15 minuted daily on average, so with the 256 GB cards i need i have footage going back many days.
