Firmware SG20160323.v2, windows 10
Started using the mSD card in May; initial samples looked good.
Just took it out to check footage - last file is from two weeks ago with half the card empty. Could see the files but could not play or copy on my PC. The unit indicates proper operation:
"When you start your vehicle the DVR is automatically started and the
recording commences, the REC indicator on the screen will blink and
the REC, POWER, MIC LED’s will indicate their status." (both my REC indicator on the screen and the REC LED blink)
but no file is created.
I tried formatting the mSD card in the unit (first time since initial use), but the old files remain; and I could not format on my PC. The mSD card appears to have failed.
Do newer firmware versions provide some visual indication when files are not being created?
