How to use:
1. Camera status:
after install the apk, by default there's only cam1 shows with name default and ip 192.168.42.1;
2. Setting menu:
click the top right corner label: For XiaoYi Sport Camera , will popup setting menu:
3. Camera setting:
[Camera Enabled] - add to connect list;
[Camera Name] - display name in main screen;
[Preview] - ON after connect, preview in VLC for android;
4. Advanced setting:
[Scene Name] & [Counter] - video custom rename rules;
[Rename by Scene] - ON will apply rename video files;
[Buzzer on Record Start] & [Buzzer on Record Stop] - camera will buzzer for 1~2 times after record starts or before record stops. this function is used for multi-cam video files synchronization;
[Volume Low on Disconnect] - after apk connect all the cams, buzzer volume will be set to mute. ON cams will resume to low buzzer volume, for the status judgement.
[Load Camera Setting] - ON after connect will check the cams resolution setting, better set to OFF.
[Camera Rename Rule]
(updated in debug 0.0.5)
by default video files will store in folder: /DCIM/100MEDIA (or 101MEDIA, 102MEDIA, ...)
if [Rename by Scene] - ON, after record finish, apk will automatically rename to:
[YYYYMMDD]-[Scene Name]-[Counter][Camera].mp4
and move to folder: /DCIM/[Scene Name]
for example: Today is 2015-09-17, [Scene Name] is "running", [Camera] 1,2,3~8 will use letter a,b,c~h, [Counter] 2-digit starts from 01 automatic increase 1 for next file.
1st record will be:
CAM1: the video file will be rename and moved to folder: /DCIM/running/20150917-running-01a.mp4
CAM2: the video file will be rename and moved to folder: /DCIM/running/20150917-running-01b.mp4
CAM8: the video file will be rename and moved to folder: /DCIM/running/20150917-running-01h.mp4
2nd record will be:
CAM1: the video file will be rename and moved to folder: /DCIM/running/20150917-running-02a.mp4
CAM2: the video file will be rename and moved to folder: /DCIM/running/20150917-running-02b.mp4
CAM8: the video file will be rename and moved to folder: /DCIM/running/20150917-running-02h.mp4
if change the [Scene Name] to "swimming", [Counter] will reset to 1.
1st record will be:
CAM1: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-01a.mp4
CAM2: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-01b.mp4
CAM8: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-01h.mp4
2nd record will be:
CAM1: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-02a.mp4
CAM2: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-02b.mp4
CAM8: the video file will be rename and moved to folder: /DCIM/swimming/20150917-swimming-02h.mp4
