Any word on if the cig power charger was shipped? BTW, I will be happy to pay for it. Also, should I try replacing the multi safer?
I'm just ready to have it working correctly. Thanks for your help!
Thanks for sending the power cord. The screen still has a blue window that says the SD card is full then restarts. It does this over and over. I've tried 2 cam and 2 power cords. Not sure it's worth anymore time to troubleshoot. I hate that I wasted so much money on this product. With that said, the customer service has been just the opposite!
Which size?The one that came with the cam
I don't know the size of the card. I'll look the next time I'm in my truck. I didn't format it. The new power cord that pier28 sent, is plug directly into the cam and the other end is directly plugged into the cig power. The multi safer isn't being used at this time. I also unplugged the gps. It's simply the cam plugged into the cig power.
They cut the cig power end off the wire and used the wire for the install.
Not sure if this is your problem or not, but if they cut the end of the cig lighter adaptor off, and hard wired it to the unit, doesn't this mean that 12V was fed to the cam (instead of 5v)? This might explain your white screen with the previous unit, as most "step" down transformers are integrated in to the male cig lighter plug.
It's a transcend 32 gb card...I just checked it out.
I just formatted the card and everything seems to be working correctly. I'll give it a couple days and report back. If all is well after a couple days, I'll try to install the newer firmware and use the card I bought that has more memory.
