This is now your
fifth thread about your questionable charging practices with the RAVpower powerbank you claim to own. What is the point in launching thread after thread about this?
Nobody ever said that charging a powerbank at the same time it is discharging "won't work". What was said in no uncertain terms is that engaging in this practice is unwise because it can damage the cells in the powerbank and can also damage your camera.
The fact that you have not experienced any problems to date that you are aware of is meaningless.
Abusing lithium-ion battery cells is a bad idea, PERIOD, but in this case the phenomenon of "mini-cycling" as a result of charging a battery bank while it is discharging can not only damage the powerbank's charging circuitry and battery cells but can also damage the device that is being charged by the powerbank. Damage may happen slowly and imperceptibly but it is indeed happening. It can potentially lead to a condition called "
lithium metal plating" inside the cells and the creation of
dendrites which are whiskers of lithium that grow inside lithium-ion batteries, which can cause the bank and devices they’re powering to lose power more quickly, short out, and in some instances, catch fire.
There is a good reason that both RAVpower and Anker
stopped offering "pass-through-charging" powerbanks years ago with one or two specialized exceptions. For example, the only pass-through-charging powerbank RAVpower currently offers is a specialized 5000 mAh wireless phone charger. None of their standard powerbanks claims to have the feature anymore and they may not have really had it in the first place. Both RAVpower and Anker's approach to "pass-through-charging" were questionable and is the reason they stopped offering the feature. Currently,
ZENDURE is one of the only powerbank companies to legitimately offer powerbanks with the proper circuitry for pass-through-charging but these are far more costly than the devices offered by Anker and RAVpower because of the more sophisticated circuitry required which is more like battery management you would find in a cell phone.
Anker Support - when Anker cautions that pass-through-charging can cause your powerbank to rapidly power on and off, they are referring to the phenomenon called "mini-cycling". What Anker is basically acknowledging here is that their powerbanks did not really have "pass-through-charging" because "mini-cycling" would be entirely eliminated in a powerbank that had the proper circuitry.
Anker Technical Support
Even when RAVpower sold powerbanks that were "supposed" to offer pass-through-charging, they recommended only using the feature "from time to time" rather than full time.
Team RAVpower support
Even when RAVpower was still offering powerbanks that claimed to have pass-through-charging they advised not to use it for long periods of time and to only use it for emergency situations. And this advice didn't even take into consideration the added stress to a powerbank that is permanently left inside the cabin of an automobile where the powerbank is subjected constant vibrations and temperature extremes, an environment they were never built for.
From Battery University -
Charging Lithium-ion
Batteries In A Portable World" by Isodor Buchmann
![buchmann.jpg buchmann.jpg](https://dashcamtalk.com/forum/data/attachments/60/60500-a7241920568f5ef6d1b14a2b8046ebc3.jpg?hash=pyQZIFaPXv)
