That was for a dual channel camera with front and rear views, plus everything needed except for the memory cards. I would suggest 128GB memory cards, but everyone has different needs and makes different choices on that.
Viofo cameras record parking mode video at low bitrate but full resolution, which normally gives a much better result than 720p, and maybe longer record times depending on which parking mode you use and what you compare it with.
Just checked the Amazon.co.uk stores, choosing Viofo's A129 Plus that I linked above against the Nextbase 622 which I take as a roughly similar quality camera, Viofo has the higher stars at 4.3 against 4.2, while the Nextbase costs an extra 76%. Against the Nextbase 522, it is 4.4 against 4.3 in favor of the Nextbase, and the Nextbase is 40% more expensive:
Next-base dash-cam
www.amazon.co.uk
But remember, Nextbase uses batteries instead of super capacitors, so after 1-2 years, you are going to have to buy a new one, or swap it for a remanufactured one at half price, while the original Viofo will still be working fine.
