Panzer Platform
- Jun 9, 2022
- California
- 2024 Minimum Requirements: STARVIS 2 & HDR
Not to say I told you so, but that was my first post. lolSo I changed the 10amp fuse that is for the powercell and bam! It is charging again. Guess I should have tried that first.
“Never” trust visual inspection of a fuse.
“Always” test suspect fuse with multimeter continuity check.
Check fuse with meter.
1.)I wonder why it blew this fuse
This is why I do not recommend charging any dash cam battery pack directly through the fuse box with an add-a-fuse tap, (or any other “high amperage device”).
The battery pack should be charged on it’s own dedicated electrical circuit isolated from any other electrical loads.
Just like a Car Audio Amplifier, LED Light Bar, or any other “high current” car accessory.
2.)
This is why I do not recommended using the included 16AWG charging cable, and instead using 12AWG.
Both of these issues are factors of aggravation for malfunction, or damaging existing OEM / factory electrical wires & components, or worse case scenario starting a fire.
Robert has documented the PC8 routinely draws 14 Amps during periods of charging, even though the internal BMS is supposed to limit it to 10 Amps.
I documented a similar issue when charging with the BBMC AC/DC home charger.
Even though the internal BMS is supposed to limit charging current at 5 Amps on “low” I found it would draw more than 5 Amps causing the home charger to overheat, and shut down causing the PC8 to go “endless boot loop”.
This is why BBMC upgraded the 5 Amp home charger to an 8 Amp version.
Here is my video demonstration / explanation to BBMC about these two issues when I tested the PC8;
No matter how much I "rant" about these two issues it will always fall on deaf ears because it means all previous battery pack installations through the fuse box with the included 16AWG wire are "less than ideal".
OK, end rant. lol
@BlackboxMyCar @rcg530 @safedrivesolutions @Vortex Radar
