Ralph2
- Jun 9, 2015
- Edmonton AB
- Canada
- BlackVue DR900x-Plus in 2022 Palisade replaced the 650
I am trying hard to come to grips with all the choices available when considering a dash camera. One that is confusing me is supplying power. I read about internal batteries.. capacitors.. super capacitors. Running off the cigaret lighter socket (which in my case is only on with the ignition) and hard wiring.
I take it the batteries (and capacitors) are to keep the camera running for a period of time.. How long?? Is this a variable that is important if you want a motion detection camera? I see there is a a gadget available to prevent the battery from running down too much... I take it this operates on a voltage basis.. is that a good option to consider? Is there a gadget that has a timed function.. set for say 3 hours and then shut the camera off?
The camera would normally come on when the car is started.. if it hard wired how does it differentiate between the two conditions? Do you need to supply two different sources.. one from the ignition.. one from the battery?
Thank you for your time
Ralph
Ralph
