Same thing but with a 3M adhesive mount.So I got a G1WH as my front dash cam but I would like to get a camera for the back. Any good recomendations?
I think tho the G1WH will be too big in the back.Same thing but with a 3M adhesive mount.
Yes I would like something with a close price range to the G1WH.What is your budget ( close to G1WH ) or higher ?
Yes, it'll be not discreet if that's the idea.
This is how it looked on my rear window:
Your wish is granted. So you noticed arrows but not the rubber band, eh?might have been less obvious without those big red arrows
So true.With rear cameras if you have privacy glass that makes a massive difference - if you have and you drive at night you really want to be thinking about something more sensitive like the Sony Exmor based cameras as other cameras would just give you street lights, head lights and that's about it.
I don't have it on the rear anymore.It is usually best to place your mount up on the headliner and have the camera just peeking out the top portion of the glass. It will be much more stealthy than sticking it to the middle of your rear windshield. If you have a G1WH the nice thing is that there are many different types of compatible mounts available that will work with the camera.
Now I have the Lukas on one and Dome Z7 on the other one.
The dome z7 seems to be around the price of the G1WH and is smaller. Do you have a video to show how good the quality is on it?I don't have it on the rear anymore.
If I had a SUV I would probably get the G1WH as a rear dash cam but I got a LS400 which will be too big for the rear window. What are your views on the dome z7?I was just sayin'. I really mentioned it and provided a link to the different mounts in the event the OP might still be considering the G1WH for his rear mounted cam in order to fit his budget. Not the best cam for the job of course, but it can work if mounted properly. A lot depends on the particular vehicle.
