Not so much info to go on but this means they didn't wire it correctly.
the wire with the fuse (probably red) goes on permanent power
and the otehr wire (probably yellow) on a fuse that only gives power when the engine is on.
when you are parked, does the camera record continuously or switched off completely?
The Battery wire is probably connected to a ACC/IGN switched supply.
Also double check parking mode is enabled in the settings.
If it worked in your previous car then the camera setting should be "on" for parking mode.
So as flip9 says, the camera is probably on a fuse that switches off when engine's off.
Red wire goes on permanent source (ie always power on the fuse)
yellow goes on source that switeches off with engine
this way The yellow wire "tells" the camera when the engine is off and
park mode should start.
J | Checklist before installation - F770 | F770 | 3 |
Similar threads |
