kotysoft
- Jun 11, 2016
- Hungary
- mini 0805, mini 0903
Hi everyone.
For first: I'm not an engineer or programmer. I'm just a enthusiastic user. I spent my whole night to research anything about capabilities of Novatek 96655 in the hope of changing bitrate, AE table, etc. During this research I found some intresting things. Maybe some of you already knew all of it, but I didn't found here in forum, so...
And sorry for my bad english knowledge and grammar mistake
WEB API
As you know, this camera can be controlled by wifi with applications, like FinalCam. These apps are using common http request to send commands and receive parameters. Fortunately it's not a rocket science, so once you connected your computer (or IOS, or Android, or anything) directly to your dashcam wifi, you can control it and read informations or download files!
How it works?
1.) Enable Wifi on your 0903 (or any Novatek) dashcam
2.) Find and Connect (directly from PC or Mobile) to it's host with password (SSID and PW are written on dashcam screen)
3.) read below...
The NanoQ (and probably other Novatek 96655 dashcam) IP is: 192.168.1.254
If you just open this IP ( http://192.168.1.254 ) in your regular browser, it will display the folder structure of your SD card, and from here you can download them and also remove them (one-by-one)
If you want to do something more, use this format:
http://192.168.1.254/?custom=1&cmd={command}&par={parameter}
Thanks to Nutsey @GoPrawn there is a full list of commands (not tested everyone on 0903 (yet)). Some of them will not work and some of them freezing/restarting your NanoQ..
USAGE EXAMPLE:
Start recording: http://192.168.1.254/?custom=1&cmd=2001&par=1
Get free space (in bytes): http://192.168.1.254/?custom=1&cmd=3017
If you found something useful in values or formats or commands, please share!
LIVE VIEW (streaming)
Nothing special. Just open the url in any player that supports RTSP protocoll (PC: VLC, KMPlayer Android: MxPlayer, etc) rtsp://192.168.1.254/{anyfilename}.mov
for example rtsp://192.168.1.254/dashcamtalk.mov
I'm still couldn't set the video size of streaming, currently it's 1920x1080@30 when not recording and 640x360@25 when recording for me.
UPDATE: When not recording, it's streaming the same feed you set for record resolution
NOVATEK FIRMWARE
Well, credits still for Nutsey. He just made a simple command line tool to pack/unpack Novatek firmwares. It is just a very early version (v0.1) and not like AFT for ambarella...
>> LINK to his post <<
I'm still intrested in changing bitrates (and AE METERING table) in Novatek firmwares, so I tried something. I downloaded the 20160329_16M and 20160329_20M firmwares for NanoQ, then unpacked with NTWFTOOL then compared them with hex editor.
The first mismatch probably something about version or date/time I dont know. IMO the second difference is the bitrate. I just opened it in IDA, but unfortunately I'm still groping in the dark...
If anyone can Identify this format and how to convert it to decimal bitrate, then which line should I change in another Roms then I owe him/her a beer!
Aaand also I don't know yet how to use ntwftool to pack firmware back once edited
Well, I hope I gave a good start for curios 0903 users. I hope somebody with experience and skills will help us to continue investigation
UPDATE --------------------------
This morning I just got a new firmware to test from Rayman. It is same as 20160705 the only difference is the new option 1920x1080@30 BOOST resolution what has 20Mbps bitrate. Currently it's for TESTING purposes
>> Firwmare_20160825_test by Rayman <<
As usual, update on your own risk
WEB API
How it works?
3.) read below...
1001 nul take photo returns filename and freepicnum or errcode
1002 enum set photo size freepicnum changes if changed
1003 nul get freepicnum
2001 start/stop 1/0 check maxrecordtime before start
2002 enum set video size maxrecordtime changes if changed
2003 on/off set looprec
2004 on/off set hdr (wdr?)
2005 enum set EV, 6=0
2006 on/off set mot.detect
2007 on/off set record audio
2008 on/off set date stamp
2009 nul shows max rec time with current bitrate
2010 enum liveview size
2011 on/off g-sensor sens. 0=off 3=max
2012 on/off autorec
2013 bitrate string vid bitrate kb/s
2014 bitrate string liveview bitrate
2015 start/stop 1/0 liveview
2016 nul shows current mov rec time in sec
2017 take video snapshot -13 exec fail
2018 save snapshot file -1 no file
3001 enum 0/1/2 phot/vid/play
3002 nul lists commands
3003 ssid string set ssid
3004 psw string set psw
3005 yy-mm-dd str
3006 hh-mm-ss str
3007 enum poweroff time
3008 enum lang
3009 enum tv format
3010 enum format SD
3011 nul defaults
3012 nul show ver
3013 nul FW update
3014 nul cmd status show
3015 nul file list
3016 nul ping cam
3017 nul get free space
3018 nul reconnect wifi
3019 nul get battery level 0=full 1=med 2=low 3=empty 4=exhstd 5=chargeon
3020 nul socket port 3333 error status
3021 nul save settings to flash
3022 get hw capacity st=0 val=3
3023 remove last user st=0
3024 get sd status 0=rem 1=ins 2=locked st=0 val=1
3025 http://115.29.201.46:8020/download/filedesc.xml
3026 http://192.168.1.254/FW96660A.bin
3029 shows SSID/psw <SSID>GITUP</SSID> <PASSPHRASE>12345678</PASSPHRASE>
3030 nul returns video mode list
3031 &str shows some cmds
3032 set network for STA mode SSIDsw
3033 turn on STA mode restart wifi with 3018 st=0
4001 file path string get thumbnail path+request path in capitals!!!
4002 file path string get preview path+request path in capitals!!!
4003 file path string delete 1 file req+path
4004 file path string del all
5001 returns 32k data NOR SPI flash?
2012 on/off autorec
3005 yy-mm-dd str
3006 hh-mm-ss str
3008 enum lang
3009 enum tv format
3010 enum format SD
3011 nul defaults
3012 nul show ver
3013 nul FW update
3015 nul file list
3016 nul ping cam
/*--------------Photo----------------*/
NT_CAPTURE = 1001
NT_CAPTURESIZE = 1002
NT_FREE_PIC_NUM = 1003
/*--------------movie----------------*/
NT_RECORD = 2001
NT_MOVIE_REC_SIZE = 2002
NT_CYCLIC_REC = 2003
NT_MOVIE_HDR = 2004
NT_MOVIE_EV = 2005
NT_MOTION_DET = 2006
NT_MOVIE_AUDIO = 2007
NT_DATEIMPRINT = 2008
NT_MAX_RECORD_TIME = 2009
NT_MOVIE_LIVEVIEW_SIZE = 2010
NT_MOVIE_GSENSOR_SENS = 2011
NT_SET_AUTO_RECORDING = 2012
NT_MOVIE_REC_BITRATE = 2013
NT_MOVIE_LIVEVIEW_BITRATE = 2014
NT_MOVIE_LIVEVIEW_START = 2015
NT_MOVIE_RECORDING_TIME = 2016
NT_MOVIE_TRIGGER_RAW = 2017
NT_MOVIE_GET_RAW = 2018
/*--------------setup----------------*/
NT_MODECHANGE = 3001
NT_QUERY = 3002
NT_SET_SSID = 3003
NT_SET_PASSPHRASE = 3004
NT_SET_DATE = 3005
NT_SET_TIME = 3006
NT_POWEROFF = 3007
NT_LANGUAGE = 3008
NT_TVFORMAT = 3009
NT_FORMAT = 3010
NT_SYSRESET = 3011
NT_VERSION = 3012
NT_FWUPDATE = 3013
NT_QUERY_CUR_STATUS = 3014
NT_FILELIST = 3015
NT_HEARTBEAT = 3016
NT_DISK_FREE_SPACE = 3017
NT_RECONNECT_WIFI = 3018
NT_GET_BATTERY = 3019
NT_NOTIFY_STATUS = 3020
NT_SAVE_MENUINFO = 3021
NT_GET_HW_CAP = 3022
NT_REMOVE_USER = 3023
NT_GET_CARD_STATUS = 3024
NT_GET_DOWNLOAD_URL = 3025
NT_GET_UPDATEFW_PATH = 3026
NT_UPLOAD_FILE = 3027
NT_LIST_CAMERE = 3029
/*--------------playback----------------*/
NT_THUMB = 4001
NT_SCREEN = 4002
NT_DELETE_ONE = 4003
NT_DELETE_ALL = 4004
NT_CAPTURE = 1001
NT_RECORD = 2001
NT_MOVIE_HDR = 2004
NT_MOVIE_EV = 2005
NT_QUERY = 3002
NT_SET_SSID = 3003
NT_SET_DATE = 3005
NT_SET_TIME = 3006
NT_POWEROFF = 3007
NT_LANGUAGE = 3008
NT_TVFORMAT = 3009
NT_FORMAT = 3010
NT_SYSRESET = 3011
NT_VERSION = 3012
NT_FWUPDATE = 3013
NT_FILELIST = 3015
NT_HEARTBEAT = 3016
NT_THUMB = 4001
NT_SCREEN = 4002
USAGE EXAMPLE:
NOVATEK FIRMWARE
>> LINK to his post <<
Code:
HEX for 16Mbps = 40 1F IDA= DCD dword_1F3DC4+0x23C
HEX for 20Mbps = 10 27 IDA= DCD dword_2708C0+0x740
