Paul Iddon
- Apr 5, 2016
- Preston
- United Kingdom
- Viofo A139 Pro 4K, A129 Pro Duo 4K, A229 Duo 2K, & NB 522GW
Conbrov T17 Dashcam Review
Thanks to Allen at Conbrov for providing this dashcam for review.
It is advertised on the box as the worlds smallest dashcam, and having seen it, I can safely say this is most likely! Once opened, the box revealed the usual components, but the most striking being the camera itself, which as you will see in the unboxing video is amazingly small. Lets see what is in the box...
Here are photographs of the individual contents:
Moving on to the video, and despite it diminutive size, the cam does OK, with 30fps at 1080p at a bitrate of 20386kbps (less than comparative B1W & Z-Edge). Unfortunately, there is evidence of softness in the recordings. I am unsure though if this is because here in the UK, we use PAL rather than NTSC and I can see no way in the dashcam to change or check which format the camera uses.
Another noticeable thing is when driving directly into the sunlight, the sun itself shows as a black hole in the sky – the lens/sensor seemingly unable to cope well with intense brightness.
There are example videos below which display just the T17, and then comparisons against 2 other 1080p dashcams (the Z-Edge Z3 Plus – the most expensive) and a Blueskysea B1W which is similar in price depending where you buy.
If you take a snapshot from the videos, you can see the softness:
In the menus you can change resolutions from VGA, HD to FHD (640x480, 1280x720, 1920x1080). The video is in AVI format. There are options Loop Recording (OFF, 3, 5, and 10 minutes).
You can set the date/time stamp to be on or off. There are time enabled screensavers, and two frequencies of 50Hz and 60Hz. The video can be recording flipped, by setting the sensor flip to on, allowing more flexibility for mounting. The T17 has a G Sensor, which has 3 settings, each of which seemed to work.
The dashcam comes with an internal 85mAh battery, powering a 110° lens, and the unit will support a 32Gb micro SD card.
Mounted on the windscreen by the suction cup, the camera is relatively discreet, though the (nice) silver edge around the lens housing may be better suited being black for more “stealth”.
The small screen is useable for accessing menus, though not for replaying video – this is best done by transferring the card to a computer for viewing.
Overall, I like the camera, but there is room for improvement in either or both the lens and/or sensor to improve video performance. One thing I did notice is the video recordings at night change from colour to black and white part way through, which I find odd.
For those on a budget and who like to have a dashcam that is hard to spot this may well suit you, especially because it is tiny, but there are other options, though not with a tidy discreet design such as the T17 offers.
You can get the Conbrov T17 from Amazon on the link below:
https://www.amazon.com/gp/B076TYQFSG
For buyers outside of the USA, the dashcam can be bought (shipping free) direct from Conbrov via their official site:
https://www.conbrov.com/product/car-dash-cam-conbrov-t17/
Paul.
Paul.
