General
Complete name : F:\DCIM\160129000\213546AA.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1 (avc1/isom)
File size : 520 MiB
Duration : 3mn 0s
Overall bit rate mode : Variable
Overall bit rate : 24.2 Mbps
Encoded date : UTC 2016-01-29 21:35:36
Tagged date : UTC 2016-01-29 21:35:36
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 0s
Bit rate mode : Variable
Bit rate : 24.0 Mbps
Maximum bit rate : 20.0 Mbps
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.217
Stream size : 515 MiB (99%)
Title : Ambarella AVC
Language : English
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 3mn 0s
Source duration : 3mn 0s
Bit rate mode : Constant
Bit rate : 128 Kbps
Nominal bit rate : 48.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 2.75 MiB (1%)
Source stream size : 2.75 MiB (1%)
Title : Ambarella AAC
Language : English
Text
Format : Timed Text
Codec ID : text
Duration : 2mn 59s
Source duration : 2mn 59s
Source stream size : 54.7 KiB (0%)
Title : Ambarella EXT
Language : English
Forced : No
