Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Thank you @GearBest for providing Mini 0807 dashcam for review.
It's available for purchase at Gearbest site: *****************************************
Summary: will be updated after tests.
Detail Review:
Description & Features: Mini 0807 is based on Ambarella A7LA50 chipset and SONY IMX322 Sensor.
Supports up to 128 GB microSD card.
It has two microSD slots so total storage can be 256 GB.
Resolution only has up to 1080p in the specs.
Screen size: 1.5inch
GPS is built in the mount.
Super Capacitor.
Support ADAS (LDWS, FCW, FCMD).
Also comes with OBD II cable as well as regular car charger.
When OBD II is in use, it's supposed to go to parking mode when car is off.
Storage card preparation
The camera supports dual micro SD cards, 2 * 128GB maximum.
The files can be stored in card A or card B. The user can insert one micro SD card into the camera or two micro SD cards into camera at the same time, providing more space to store videos, images or other files. Please use high-speed micro SD card meeting the specification of TFHC. (Class 6 is ideal .Class10 may cause some problem because the speed of card is too fast, it is better not use Class10 card)
Copy function for backup video
Video clips can be copied manually between card A and card B, then you will have backup after you need to hand over one card to police or the court.
1. Please choose card in Playback.
2. When camera is in standby, long press DOWN button to enter video playback or photos playback. Then long press UP button to enter playback sub-menu, you can see COPY FILE TO ANOTHER CARD, options are YES/NO.
3. If you press OK button to choose YES, the OKed video or photo will be copied from this card to another card.
4. Please note the user can copy only one video or one photo to another card each time, not all the files.
Choose MicroSD Card
Here you can choose the card which you want to store the videos and photos on.
Options: Auto / CARD A / CARD B
If there is only one card in camera body, this card will store videos and photos by default.
If there are two cards in camera body,
1. Here choose Auto, loop recording between card A and card B. Please make sure you do not set Recycle of Menu to OFF, otherwise once the recording card is full, the other card will not start to record.
2. If CARD A or CARD B is chosen, only CARD A or CARD B will store videos and photos, there will be no loop recording between two cards.
There is another choice in card sub-menu in playback, not the same as here.
Package Contents:
![DSC04845-mini0807.jpg DSC04845-mini0807.jpg](https://dashcamtalk.com/forum/data/attachments/23/23539-4264f0f525d5ab85dc1e952f0c4930f6.jpg?hash=QmTw9SXVq4)
Mini 0807 Dashcam Unboxing video:
Mini 0807 Side-by-side with Mini 0826 dashcam:
0807 is shorter but slightly thicker than 0826.
0807 has dual microSD slots on the bottom.
![IMG_0359-mini0807.jpg IMG_0359-mini0807.jpg](https://dashcamtalk.com/forum/data/attachments/23/23540-1bef3c7fcaa1eaca37fb67f4755288f4.jpg?hash=G-88f8qh6s)
Micro USB charging port is on the edge of the mount instead of on the side as in 0826.
![IMG_0361-mini0807.jpg IMG_0361-mini0807.jpg](https://dashcamtalk.com/forum/data/attachments/23/23541-a18f73482b8bc135e6b9a003da82178a.jpg?hash=oY9zSCuLwT)
![IMG_0362-mini0807.jpg IMG_0362-mini0807.jpg](https://dashcamtalk.com/forum/data/attachments/23/23542-fb7e1a60ed8db5d91cf4024846c75912.jpg?hash=-34aYO2Ntd)
![IMG_0363-mini0807.jpg IMG_0363-mini0807.jpg](https://dashcamtalk.com/forum/data/attachments/23/23543-2e2c99d76da8cbd1d55a343700e4857e.jpg?hash=LiyZ122oy9)
More coming soon...
Detail Review:
Super Capacitor.
Choose MicroSD Card
Package Contents:
- Mini 0807 Dashcam,
- Sticky mount with GPS and two extra tapes,
- Micro USB car charger,
- Micro USB PC cable,
- OBD II Cable (2.5m Approx.),
- Lens cleaning cloth,
- Wire management tabs,
- Windshield films,
- Product manual.
More coming soon...
