Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
Def better video but iffy. Specially heat rendered focus issues. Still am taking a gamble here and prepared to lose money on this or maybe convert it to use as wifi based cctv if all else fails.@Sanjay
Xiaomi yi has better video quality as of now.
Check videos here: https://dashcamtalk.com/forum/threa...96p-wi-fi-adas-dashcam-golden-gearbest.17205/
It's been working great except it shifts focus when hot like parking under the sun but still better than original OOF videos.So do the fixed focus stick, or do it go out of wack again as soon as the car get a little sun/heat while parked.
Thanks for the fast reply. Appreciate it.
I am amazed at how dedicated u guys are here on DCT [emoji106]
Sent from my XT1060 using Tapatalk
General
Complete name : E:\DCIM\100MEDIA\06241153_0005.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 340 MiB
Duration : 3mn 0s
Overall bit rate mode : Variable
Overall bit rate : 15.8 Mbps
Encoded date : UTC 2016-06-24 11:53:19
Tagged date : UTC 2016-06-24 11:53:19
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 3mn 0s
Bit rate mode : Variable
Bit rate : 14.9 Mbps
Maximum bit rate : 18.0 Mbps
Width : 1 920 pixels
Clean aperture width : 1 920 pixels
Height : 1 080 pixels
Clean aperture height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
I was talking about what I can do with the xiaomi yi, which I bought as a stop gap cam till mini 0807 is perfected, if there still is heat related OOF effect with xiaomi yi even in the new batches [emoji3]It's been working great except it shifts focus when hot like parking under the sun but still better than original OOF videos.
No problem.
Yes heat issues will be there unless hardware is changed.
Mini series is right next to windshield so gets hot quickly.
BTW, mini 0807 doesn't have Wi-Fi.
Hope the vid quality improves without heating up the cam any more.I loaded the new 20160623 V1.0 firmware.
Overall VBR is around 14.9 - 15.8 mbps.
Video VBR is 14.6 - 14.9 mbps and audio is 128 kbps.
A 3 minute file is 327 - 348 mb in size.
Code:General Complete name : E:\DCIM\100MEDIA\06241153_0005.MOV Format : MPEG-4 Format profile : QuickTime Codec ID : qt 0000.00 (qt ) File size : 340 MiB Duration : 3mn 0s Overall bit rate mode : Variable Overall bit rate : 15.8 Mbps Encoded date : UTC 2016-06-24 11:53:19 Tagged date : UTC 2016-06-24 11:53:19 AMBA : Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Format settings, GOP : M=3, N=15 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 3mn 0s Bit rate mode : Variable Bit rate : 14.9 Mbps Maximum bit rate : 18.0 Mbps Width : 1 920 pixels Clean aperture width : 1 920 pixels Height : 1 080 pixels Clean aperture height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) fps Color space : YUV
Will test out on the road soon.
Here's one for now:raw file, please![]()
The top one called bitrate.Sunny. Can share the link for the firmware?
Very impressed with the new FW. The video quality made a large leap in improvement. Hope these developments continue.Mini 0807 High VBR Firmware Test videos: 15.6 Mbps.
Evening time so not too bright.
@Olgu
The new firmware only gives around 15 mbps, not 20 mbps video bit rate for me.
Maybe different lighting conditions and scenes add more bitrate.
I'll test in daylight soon.
