Lunar
- Sep 26, 2013
- Herefordshire
- United Kingdom
- 3x Mini 0801 / Mio-368WDR+AGF
I am having similar problems - shuts down while driving.
I am not convinced that it is a power connection problem.
Power is going directly to the dashcam, not via the GPS/mount.
With the original 16G Class 10 card, it worked fine for a while, then started shutting down.
I thought it may be due to the card, so bought a 32GB Sandisk Class 6 card.
This had worked fine, for a while. Then it shut down.
I can re-start by pressing the on button on the side.
Starts up and runs ... for EXACTLY three minutes, which surprise, surprise, is the period I have set it to roll.
Stops - press button - starts - rund for three minutes - shuts down. Repeatably.
Looks to me like a FW problem when the card fills.
I have just re-formatted the card and set the roll to the default one minute.
We will see what happens when the card re-fills.
I am guessing that it may be ok, that it was only ever tested fully with default values?
So it's not shutting down, but stopping recording after a period of time which you state coincided with the loop time you have set.
I assume you have tried doing a full reset by holding down the on/off for 20secs or so.
Who supplied your camera ? And which model is it ? (ie. GPS only ? or GPS + 8gb or Std). What firmware is currently installed ?
You say you don't think it's the power connector..why do you think that, are you basing that on the fact the camera remains still powered up when it stops recording? If so...I respectfully suggest you don't underestimate the weird symptoms the connections on these cameras can cause, especially typical is stopping recording for no apparent reason.
I'm not saying its causing your problem especially as you are connected directly to the camera, but based on my own experiences they can cause problems. Have you tried other cables? I have several USB to mini B USB cables and most work okay, but one which works fine with other devices does not work properly with this camera, the camera powers up but never goes into record mode with that particular cable..no idea why, but there's something different about that one cable it doesn't like, it's a decent Belkin make too.
You say it worked okay previously for a while at default settings, (how long is while ?) which would suggest the firmware is likely okay at default settings, TBH I only use default settings except for the screen off time which I prefer to go off almost immediately.
One cannot rule out anything with these particular camera's...lol. I would certainly try other cards if you haven't done so just so it can be eliminated from the culprit list.
