Some G90C issues
Feitelijk
Netherlands
SG9665GC GT680W G90C GT300W
Recieved it yesterday from Foxoffer. (with a surprise unordered GPS reciever)
Some issues:
-battery doesn't seem te be charging (altough I see the blue light). After disconnecting the camera immedeately complains about lowbat (also after 2 hours of charging) and switches off without saving the file.
-It stopped recording after twelve minutes and then produced empty files.
-Wouldn't turn off after disconnecting from the computer USB. Have to use reset button.
All in all, I'm not that satisfied.
Questions:
Can you set the GPS to kph instead of mph?
Is there any way to set EV?
Feitelijk
Feitelijk
Netherlands
Charging for 4 hours filled the battery.
I hope that's only for the first time charge.
Mandami
France
G90 A7LA70 1, 2, 3, 4
I think it's better to set Delay Power Off to 15 sec. In this way when the charger is off, the camera will automatically shutdown after 15 sec and it will force the save of the last file. The last file will have different lengths. When this parameter is OFF and there's no external power source, the camera will record until the battery if depleted.
Auto Power Off Settings is for the case when the camera doesn't record no mater if it's connected or not to an external power source.
maybe there's a problem with the SD card; try another one.
yes use this firmware: https://drive.google.com/file/d/0Bw8LfG-2RaLhQUlOQ3BOai00Ymc/edit?pli=1
To install it use this thread, for example : https://dashcamtalk.com/forum/threads/gs90c-new-firmware.11884/
Me too I'm interested; work in progress. when I'll find a good solution I'll post it.
Feitelijk
Feitelijk
Netherlands
Ugraded to that firmware. Will see what it does. I don't see the kph option in the menu yet.
Feitelijk
Feitelijk
Netherlands
Good enough for me. Althoug I would prefer a "km/h" label instead of 'km"
One more thing.
It looks like the cam stops recording after an "EVENT", at least I found twice that it did not record the entire drive and the last file was in EVENT. Is that something you recognize?
Mandami
France
That's normal because "time is money". So in order to reduce the production cost they had to remove the "time".
what kind of event ? If you're using 1138, then both the shock sensor and event button work without problem.
What are your settings ? If motion detection in On, then shut it down.
Feitelijk
Feitelijk
Netherlands
. I did not pucsh any event button. I switched off motion detect and it looks fine now.
Just noticed a crackle in the sound, end a USB connection to the PC that cut out.
Not too impressed with the image quality either, but that's comparing to a F1.6 GT300W
In fact I would categorize it under crappy, I thougth it would be better on the 60fps 1920x1080p
or the HDR
but no.
Mandami
France
Can you identify the plates number in your clips ?
Somehow it looks that the bonnet is clearer compared with the objects further away.
I had a similar problem which became worse with the time. In the end I had to open the dashcam to fix it (!! I'm not 100% sure your problem is similar):
https://dashcamtalk.com/forum/threads/g90-a7la70-unfocused-videos.7226/
Here a recent clip recorded at 2560x1080 for comparison (you have to see it at 1440p on youtube to get something closer to the original; there are many dashboard reflections)
And what is this strange effect around the head and tail lights?
Guess is HDR related
Possible; have you tried recording in other mode ?
Feitelijk
Feitelijk
Netherlands
Goddammit! Again my trip of yesterday was cut short to 25 seconds! :mad:
Simply stopped recording, no files present. I did check the cam during the trip and it looked fine. red dot pulsating and all.
Feitelijk
Feitelijk
Netherlands
When I use HDR 1080p (and only there) I get the time and speed in huge letters on the display, in the video it is stamped in the same size as the others though. Funny.
Mandami
France
It doesn't sound good; try another SD card, and, why not, another power supply.
The same on my dashcam.
When I received my dashcam last year the records weren't too good. In the end I had to open it and refocus the lens. It's not complicated, but this operation has to be done with care (to avoid other damages).
Feitelijk
Feitelijk
Netherlands
This is the second SD i tried, and both of them do not show problems in other cams.
Man, even my GT680 had a MUCH better picture than this.
I'll try the refocus, but will be ordering an LS360W to be able to see licenseplates again... :rolleyes:
Feitelijk
Feitelijk
Netherlands
Got it back together again. Pfffft.
Looks like the focus is a bit better now. Will have to wait for a drive and see.
Feitelijk
Feitelijk
Netherlands
Also I'm not sure about this HDR, are trees supposed to be blue?
Mandami
France
Then try another power supply. Many years ago I had a very strange behaviour with some PC power supplies. Anyway, what type of SD are you using ?
Louis Armstrong will say green :D On the other hand, it's '"normal", the same happens with my dashcam.
This chromatic aberration is a result of the lenses.
Mandami
France
Refocussing helped a bit:
It looks better. If you remove the 3 screws and the silver ring, then you can adjust the focus anytime you want.
Bo$s G90 3
Pianoman144 G90 1
camerahanhtrinhvn.com G90 6
V G90 2
B G90 25
