Sound interference?
Julia
I installed my SG today. When watching the video playback the sound has a lot of interference type noise.
My car is a plug in hybrid and has lots of electronics going on. I did have the DAB radio on could this cause the noise?
I would upload a video but some IT skills escape me.... I will keep trying.
Thanks
Thanks
Can you try plugging it into another car as a test to rule out your hybrid? When did you buy your unit? (what's the serial number off the back?)
You can share a raw .MOV video clip if you use http://mega.nz or http://dropbox.com (and then share the public link to the file/folder)
I haven't got another car to try it in, I could ask a friend. I have done the video I think:
I have just bought it from Hiniko. The fw isn't the latest but the one before IIRC from looking at it earlier. I will get the S\n later the car is locked up in the garage atm.
thanks
it sounds like it's vibrating, that may or may not be the case though, will ask @niko to get in touch and he will replace if necessary
Did you add the included EVA foam pad? That will help
it sounded like it was rattling at the start but the sound got louder as it went on, need to check serial number and firmware version but if that checks out it might be a hardware issue, I don't think DAB would cause that noise
Hi, no I didn't add the foam pad. I will do that tomorrow and then post back.
Thanks again ๐Ÿ˜‰
Thanks again ๐Ÿ˜‰
that may help but I'm not sure it is just the rattle, let us know the serial number of the camera and the firmware version when you get a chance also
Thanks again ๐Ÿ˜‰
PM sent.
I will look after you.
PM received, thank you for your top class service and help.
No problem. I am going to look after you and sort this out.
I followed your advice and after moving the camera to a slightly more central position I applied some of the foam pad and I am happy to report that the sound is now great, apart from my singing, no nasty rattle noises anymore.
Once again thank you very much for your help and advice, its second to none.
I am glad it is sorted out for you.
If there are any further help needed please feel free to ask.
Here is how it sounds now... Great.
I have ordered a CPL to help reduce the reflections from the dash.
Thanks. I will dispatch tomorrow.
