SSD doesn't worked - solved
Hello colleagues!
I have done some tests on a combination of ssd modules and external boxes. The most stable combinations where the power consumption of both the box and the ssd module did not exceed 7.5 watts.
I chose combinations with 2.5’ box and with maximum TBW. Because these boxes are the coolest, and even slow ssd's write speed is always enough to work with Viofo A329
Hello colleagues!
What brands did you test and what were the results per brand?
The test lasted for 2 days ( travelling 3 hours each day) and 2 nights ( 8 hours each night)
Blueendless Box Sata (chip Jmicron JMS580 Firmware Version 00.02.00.04)
Noname Box Sata (chip Asmedia ASM1051 Firmware Version 200416_D1_48_02)
Agestar Box Nvme (chip JMicron JMS583 Firmware Version 00.02.00.08)
SSD sata Intel DC3510 800 Gb
SSD sata Micron 5300 pro 1.92 Tb
SSD sata ADATA Ultimate SU630 960 Gb
SSD NVME m.2 Smartbuy PS5008T-2280T 512 Gb
SSD NVME m.2 Samsung 990 Pro 4 TB
MSI Spatium S270 960 GB
Blueendless +Intel= No work
Noname+Intel= No work
Noname+Micron=Working, all function, cold
Noname+adata=Working, all function, cold
Noname+Msi=Working, all function, cold
Agestar+ Smartbuy PS5008T =Working, no stable, warm
Agestar+ Samsung 990 Pro 4 TB =No work
And these all work on pc. It seems to be the same with external SSDs, some work, some don't. Something isn't right on either Viofo or Novatek with the drivers.
Pshotos boxes
Thank you seis1, nice data and good to know what will and will not work. Appreciate the effort!
, viofo is very low compatibility with enclosures.
Nice work. Very detailed.
It’s funny that the only enclosures work which is noname , it’s hard to find on amazon, we need a little gamble to buy with just a image of enclosures, most of noname manufacture don’t show the chip in techspec
Anybody else feel quite bait-and-switched by this debacle? Nowhere on the listing or the site was it mentioned that external enclosures are not supported, and USB is a universal standard. Something in the A329 firmware is ungracefully exiting the write operation to the drive; when I plug it in to my Windows computer it always wants to "scan and fix" it, but there's then there's no errors detected.
I always had the same message display as well, flash storage is pretty good at not corrupting or having data loss. But yeah I totally feel the same so sold my Kingston SSD that doesn't even need an enclosure.
Bait and Switch is an intended act of fraud, that is not something VIOFO did with the mess up about SSD drives. However, like you, I agree there should be zero issues with virtually any SSD being recognised by the A329.
The message you are getting when you put that SSD, or any MicroSDXC into a Windows unit could be caused by several things.
  • If the SSD/SDXC is formatted FAT32 or ExFAT and your Windows is natively NTFS, then Windows may want to 'fix' the SSD/SDXC.
  • Ejecting the SSD/SDXC from the dash cam while the dash cam is still powered up, bad file closure, possible corruption to file system.
  • If for some reason the SSD/SDXC was ever bootable. Not likely but honestly, I have created a Linux bootable SSD/MicroSDXC card.
There probably could be more reasons but those are the most likely possibilities. I have gotten the same message when pulling a memory card from the dash cam or my Linux box and then inserting into my Windows box. This has little to do with the dash cam file system (dash cam boots Linux kernel) and more with Windows, in my view. Though I do believe there are issues with the VIOFO file system and how it is used, purely opinion, no proof on that part.
edit::clarity_about_memory_devices
The message you are getting when you put that MicroSDXC into a Windows unit could be caused by several things.
When did I ever mention a Micro SDXC? I'm discussing the 2TB Kingston m.2 NVMe SSD that I'm trying to use as recordable media since all of the documentation and marketing said I could.
Same difference as far as the file system cares. NVMe is only a protocol, the SSD is still formatted in ExFAT or FAT32 or whatever.
Not to split fine hairs, but the VIOFO documentation never mentioned Kingston. Now, I do agree the Kingston should work, I agree my Crucial X10's should work...VIOFO feels otherwise and late in the game, they adjusted their marketing. That is not 'bait and switch', that is simply screwing up.
I mean, "late in the game" here meaning after the dash cam was released for sale? They didn't provide *any* guidance in the documentation regarding what was or wasn't supported. VIOFO literally just stated "external SSD" without any further qualifications or specs. Did they not think to test with a wide variety of configurations before making that claim? That, to me, is a bait-and-switch or at the very least they should pursue the issue further by collecting logs from those affected to see if any improvements can be made in the filesystem.
If the SSD/SDXC is formatted FAT32 or ExFAT and your Windows is natively NTFS, then Windows will want to 'fix' the SSD/SDXC.
By the way, this is not true at all. I have several external SSDs, flash drives, and SD cards that are formatted as exFAT and Windows doesn't show the dialog box to "fix" the drive. This has to be an issue with how the VIOFO firmware is exiting the file system.
  • If the SSD/SDXC is formatted FAT32 or ExFAT and your Windows is natively NTFS, then Windows will want to 'fix' the SSD/SDXC.
Perhaps I've taken what you wrote out of context
Have i got this right in what you're saying?
That fat32 ext32 will always prompt to fix the memory device when used in an ntfs windows system.
That's incorrect.
I don't have that problem every time i insert the m.2 or the micro sdcards in my ntfs computer.
As always, folks split fine hairs to support their stance on a matter. In the US, bait and switch is a type of fraud and is frowned upon by the FTC and the courts. If you truly feel VIOFO has done a bait and switch, then you should file an FTC complaint!!! As far as I recall, VIOFO stated clearly the SSD devices that would work, I just checked their site and the four devices are still listed. I believe that VIOFO made the mistake to include enclosures, or similar as I recall. That was an error on their part, they realised the error and have since corrected that error.
No absolutes when dealing with Windows. No absolutes when dealing with various SSD/MicroSDXC/MicroSD cards, their housing, their enclosures, their readers etc. This has been an ongoing and known issue for years, some people experience it and some do not. No guarantees. But as I said in post #51, there are issues with the VIOFO file system and software and that encourages the 'fix' issue with Windows.
But, being the good sport I am, I will edit this statement ...
to read ...
This should ease your mind.
That's incorrect.
As I stated in my reply to metaphase ... there are no absolutes. But, this is a known issue for years, regardless of the presence of VIOFO in this matter. The fact you do not experience it does not mean my statement is incorrect, it means you have been lucky in this matter. Now, the 'fix' issue is more apt to happen with a FAT16 or FAT32 format than with a ExFAT format. But, as I indicated in a previous post, I do believe there are probably issues with the VIOFO file system.
In a fair shake to VIOFO, I have experienced the 'fix' issue going from Windows to Windows and Linux to Windows, using various readers. No absolutes, no guarantees, so I do not believe that VIOFO is solely responsible for the 'fix' situation.
edit: spelling, wording, additional text
I’m using an Orico 40 Gbps NVME enclosure with a Crucial P3 Plus 2TB SSD and it works flawlessly using almost any USB cable I try (Ugreen, Amazon Basics, and a couple of no-name cables.) The only cables that have flat-out refused to work are some Thunderbolt 4/USB 4 cables.
Which model Orico are you using?
Thanks for the data point, but as lufa alluded to, there are multiple 40Gbps enclosures available from Orico. Do you have a link to the listing that you purchased the enclosure from?
