agw
- Apr 23, 2016
Nice meeting you all,
I just switched my old DR650GW-2CH to a newer version which supports cloud access. I have some feedback and some questions:
1) The proximity sensor no longer turns Audio on or Off, instead it starts Manual Recording. Reading some older posts it seems this is a 2.002 feature.
I'm not sure what the difference is between Normal and manual recording but I miss the feature of turning the audio on or off.
Does anyone know what Manual recording does (besides having a thumbnail displayed)?
Is there any other way to turn Audio on besides changing it in the firmware and restart the camera?
2) With WiFi on, the camera (on the switch sensor side) and the power cable (by the jack) get really hot (I can get an exact measurement if needed). Is that common? By the way I simply switched the front and rear camera and reused the original installation (cable and so on)
3) Local Access. When the camera is connected to my home network, any cloud operation is still done through the cloud and I suspect the server is too far from US so there is a lot of buffering. It would make more sense to be able to access the video via the Local Area Network. The best I could do was getting the live feed from the front cam and the list of files but connecting with FTP does not work. (Connection refused before passing "root" and "pt")
4) PC Access. At this time there is no PC access from either Cloud or LAN.
Ideally, the Desktop App could be slightly modified to allow direct connection to the Camera while on the LAN.
I thought that I could possibly map a drive on the PC to the cam file list and use it in the desktop app but not joy.
5) Wi Fi Failed message. It seems that upon reboot, the wi fi connects fine to my home network but if I drive away and then come back, I get a repeated message "WiFi failed" and I have to reboot the camera to make it stop.
My only reason for switching the camera was to be able to get home and review the videos from my PC and download what I wanted but as I write this I totally turned WiFi off and emailed Pittasoft CS.
I'm not even going to discuss the bitrate issue as I understand it is being addressed.
Any comment is appreciated.
