The best microSD card for GT550WS?
slayer
Poland
I would like to to ask which microSD card do you recommend for GT550WS?
IBM
Uzbekistan
Transcend 16Gb Class 6 or Class 10.
I have installed Class 10, everything works OK.
Pavl
I'm using a SanDisk 32gb, class 10. Directions specify at least a class 6 and when I tried a class 4 that I had lying around it didn't like it. But this one works perfectly.
https://www.amazon.com/gp/B009QZH7D8
Ming06
Ratchaburi
Thailand
LS300W, LS430, LS430W, LS650W, G1W, GT680W, GT550WS, G510
Kingston MicroSD 32GB Class4
I purchased it at the price of $19.50 (Thai baht ฿619)
Works great no problems
& Save cost :)
forcedfx
I'm using a Sandisk 16GB class 4 and it works fine for 1080p at 30fps.
MrFluff
I put a Samsung 32GB Class 10 in the GT550W. Seems to work.
REyewitness
Retailer
Langley
GT200W, GT680W, GT550WS, G1W-C, K6000, SJ4000
We tested lots best ones we found are Adata class 10 32gb And Patriot same specs. Its what we ship with, and no issues.
Jam2180Cal
Calgary
I have successfully used a 64GB ADATA Premier UHS-1 (part number: AUSDX64GUICL10).
REyewitness
Retailer
Langley
64gb will work but its not officially documented by the manufacturer
REyewitness
Retailer
Langley
Curious if you needed to do any special format procedures
kuoh
When I had the GT550WS, I put in a Sandisk 64GB that was taken straight out of the package and it worked fine. It was formatted with exFAT.
KuoH
jokiin
Too many ¯\_(ツ)_/¯
KuoH
works and compatible are two different things, if you can't format it in the camera and then use it then I wouldn't class it as compatible
kuoh
I didn't think to test that, since it was working, but now the camera is no longer in my possession. I have to say though, I typically format my flash memory using a computer, not in the device, ever since I encountered digital still cameras that wouldn't format correctly.
KuoH
