bob santos
- Mar 16, 2017
- Malaysia
Hi! I had just placed an order for a T5e, just couldn't resist the many good results and the many good things everybody said about this handsome little cam.
I was wondering, is the Dual Battery Charger by ThiEye compatible with T5e batteries? Has anybody bought and tried them? Reason is very simple, I don't think it's a good idea charging with the battery inside the cam body for few simple reasons:
1. charging will make the battery goes warm, and this heat will spread inside the cam body, which isn't good for the components in the long run.
2. assuming your charging with a powerbank, I am not sure if the unit is still usable during charging and if not, one has to wait a pretty long time for the battery to charge-up. Even assuming it is usable during charging, I wouldn't use it simply because charging will create heat and operating at the sametime will produce more heat and therefore will likely cause the unit to explode or damage, just like some mobile phones.
I am pretty sure someone must have tried the t5e battery on the dual battery charger by now, although in their website, the charger is compatible only with their i60 & i30 cams. And again from their website under the Accessories section, both the pictures of the battery for i60 & t5e look exactly the same, see the screenshot below. So I am wondering if anybody has tried it out and let's hear some replies please, you would greatly help a lot of us.
Taking further, that would be a HUGE BUMMER if they aren't compatible, afterall all of these are all similar action cams.
So big thanks for any replies here.
