CyberSalami
- May 7, 2015
No dashcam product is Military/NASA heat shield perfect, but we will continue to make all Street Guardian products better and not cheaper when it comes to keeping over all long term stability in multiple environments. When the heat is the worst of the worst (even beyond CMOS rated specs) important thing is focus returns to normal. Many low end products the heat shift focus is a one way process. (perm)
On the other hand, what's the news since you said you were looking into it?
Well, I don't expect them to survive temperatures of 250+. But in hot climates such as Texas/Arizona/SW USA, and I guess Australia, SG should look at stuff that can withstand up to 200 degrees - standard. Cars get very hot in those climates, and it's a PITA to take the thing off and inside each time you park your car. It might be an idea to offer a one-by-one made "Extreme Temps" model.
For any device to withstand 200F you'd be looking at hundreds of dollars. At these temperatures, all kinds of thing break down - not just sensor or processor. Even passive components (resistors, capacitors) would have a hard time. You could probably forget about surface mounting - which means much bigger components and camera.
I ended up doing this many years ago when I have a Blackspew camera as it wouldn't stand the heat in Australia, it worked, but you need to turn the microphone off as all the sound it will record is the fan, loudly. I took the light end off and drilled holes in the other end so air would flow through.The other idea might be a micro fan in the unit - that's what I am getting ready to do with mine. I have a 5V micro fan and i'm going to place it inside the unit and see if it helps.
Any news from the Lens supplier?
