Time to replace my F770 - What to change it to?
So my F770 is playing up. I'm now getting the pink highlight issue on certain recordings and it also seems to have corrupted my main micro SD card which is no longer usable as I cannot erase it.
The front and rear cameras are hard wired and I have a battery back up installed for parking recording. The cameras are hard wired and I really want to use the same cabling so I don't have to re route all of the cables again. (The rear cable has been run under the roof lining and was a real pain to get right).
Does anyone from @Thinkware Dash Cam that can recommend a new front and rear camera that can use the existing cables? If not, I'll start looking at cameras form other companies as well?
The Q1000 or U1000 models will both use the same Power & Front to Rear cable as the F770 🙂
Only those two uses the same hardwire kit and rear camera cables like F770? What about F790, T700 or Q850? Thanks.
Yes, in addition, F790 uses a dedicated hardwiring cable among other Thinkware Dash Cams which makes it not compatible with others. There's no more F770 rear camera as well as rear camera cable compatible with the new Thinkware Dash Cam line up available.
F790 and T700 use the same rear camera and rear camera cable but not Q850
