F770 Reuse Wiring for Replacement Camera
pxr5
If I were to replace my front F770 camera can I use the existing wiring for any other Thinkware camera. Also to reuse the existing rear camera with the new front one. Thanks.
Thinkware Dash Cam
Retailer
Vancouver, Canada
U1000, Q800PRO, X700, FA200, F70, M1
Yes, you can re-use your wiring. Your rear cam compatibility depends on the dash cam you upgrade to. Which dash cam are you looking to get?
Maddog1974
Retailer
Colchester, Essex
Thinkware U1000 Front & Rear with RADAR.
U1000 is a perfect replacement as power and rear cam cable are identical. F800/Q800 the rear cam cable has the micro usb connection 180 degrees out, it will plug into them but the cable will point downwards and have to be looped back up towards the roof lining. It also then obstructs the power plug slightly making the power plug tight to go in (it would go in carefully though).
P
pxr5
I'm looking at the U1000, so all sounds good. Thank you.
TKSX
U1000 should be a perfect replacement. Depending on the mouting position you might not even have to remove the old mount.
