- Feb 5, 2015
- Sydney
- Australia
- VIOFO..DOD..
@RavenManiac thank you, I solved my issue of getting a rocking motion from the 0806 due to the ill designed mount that interacts with the body of the DVR, they may have solved the connection from getting loose but the design on the mount is or can be a big let down if like me you discover the rocking motion
this is how I solved my issue
a cable mount was wedged at the mounting section and then to counter act that I had to wedge a foam at the other end an, I am not a designer by any stretch of ones imagination and can be seen, what a let down when people see this DVR and I explain why its bodged up like it is
but surely people that handle the material its made of day in day out would take less than 3 minutes to see this is a very weak point, I am sure they (whoever agreed with this design) went with style above function when it came to its implementation
I had noting but hassle with my Blackview DR500GW, so much so I will never be seen with any of their products EVER, but one thing I will say, they designed the mount very well, in fact I would say it is truly a DVR that can be moved from one car to another year in year out, with no issues what so ever as the mount is just great, with the 08XX range, I dare not remove the DVR from the mount un less there is a very good reason for doing it and for moving it from one car to another (for me) is not a good enough reason as the mounting point between the DVR and mount are just not design good enough, something will give and more than likely it will be the snap of the mount
Now if only the Blackview delivered what was promised with the DR500GW I would of been pleased
here is the mount on the DR500GW, the people behind the 08XX should take note
The Nano Q might be moving things in the right direction with regards to centrally located mounting options.
