Thank you for the link Raven, I only stumbled on it by chance at the end of last week, and see I’m not the only one
I’ve tackled this from a different angle but hopefully with the same or better results
as I/we have discovered the DVR rocking in an up down motion, sea-saw like
after taking a look at the mount, I thought if I wedge some material (card like) in the gap between the DVR body and the mount, hoping this will eliminate the sea-saw rocking.
I’ve not yet got the 0806 back in the car to test it out but will do sometime this week and report back
I ended up wedging a cable tie in the gap, the cable tie is just thick enough to give slight friction when I slipped it in the gap, it can be pulled out with only slight friction. if this does’t work then looks like I’ll have to get out my craft knife and follow Niko’s instructions
one thing with the method I’m using, unless I glue the cable tie either to the body of the DVR or to the bottom of the GPS mount but not both, (I don’t plan to but) every time DVR is slipped out of its mount, the cable tie will be lost on the floor of the car
here are a few images showing the cable tie in the gap, if it does work then I’ll trim it, but for now I’ve left it so I can pull it out easily,
also I’ve followed others in sticking a bit of tape on the micro card for ease of inserting and extracting, hopefully not shoot out the car on to the road or where I’m parked at the time
One bit of good news, after hearing that there is on some 0806’s issues with using both card slots, last night I inserted a 32GB card in slot B, the slot under the DVR and a 64GB card in the top slot A
Card choice was set to auto, and left it running yesterday morning, then in the afternoon I went back to it and took out the cards. I was hoping it would of started on slot B, easer to take the card out when the DVR is fitted to the windscreen, and it did.
when that card filled up it started on the 64GB card in slot A.
after upgrading the FW to Nigel’s FW, it uses roughly 175meg per second, about 12gig per hour so two 64gig cards should give me about 8 to 10 hours of recording
I went to Staples yesterday and got myself a portable 2TB HDD paid on’t £70 and while I was there I took a look at their micro cards, iirc the 128gig was around £100, so I skipped that for now, maybe next year they’ll come down to the same price as 32/64 gig cards
