SoCalDude
- May 25, 2015
- Sunny Southern California!
- Black Box G1W-B
I don't believe the camera does a full format. It does the equivalent to a quick format, which basically clears-out the FAT table and all the links down the chain. It doesn't go sector-by-sector like that of a full format. That's why the in-camera format is a quick process (instead of 30-60 minutes). Because of this, it doesn't change the underlying cluster size, so whatever the cluster size was from the factory, that's how it remains.If the camera formats the cards in FAT32 with a 32Kb block size, there must be a reason for it and apparently Windows formatting tool "respects" that, otherwise it would always show a 16Kb block size for FAT32, right?
Now, if one changes this cluster size (via a Windows or other gui formatting tool), then that size survives an in-camera format. If the firmware can't handle that modified cluster size, then you may see the error that you mentioned (not recognizing the card).
