murcod
- Sep 30, 2013
- South Australia
- Australia
- Mobius, A119v2, A119v3
Tony the problem seems more common for Diesel users, since there is a need in the winter to warm the the plugs by turning the key to ACC for a few seconds first. This is the same scenario as Jim. I don't find the situation as common on my gas engine since I start without hesitation normally. I will say if you let the cam start recording (blinking red lights) in ACC it will stay on after you start, so timing is everything. It's just not a great scenario to revolve your start up around the cam, so a fix is needed.
The problem is people are powering the Mobius from power circuits that have the power cut to them when the engine is cranking over.
There is a relatively simple solution that will work in that situation:
You could try locating a different power source for the Mobius. Vehicles usually have an "ignition on" power circuit that remains "live" while the engine is cranking; other non- vital power sources are cut to maximise power to the starter motor (ie. the cigarette lighter socket loses power.)
Try connecting your Mobius to the "ignition on" circuit which remains live and it may sort your problem.![]()
It will involve hard wiring the Mobius to the "IGN on" circuit that doesn't have power cut to it. The vehicle's engine ECU power supply circuit would be the ideal place to hook into - that will definitely have power when the engine is cranking.
