murcod
- Sep 30, 2013
- South Australia
- Australia
- Mobius, A119v2, A119v3
I see a shutdown bug was confirmed on 1.20 so maybe better not to use that while trying to troubleshoot the problem
I had my first Mobius problem last week after going to 1.20 . My car has keyless start (ie. push button) and when you shut if off it kills everything (ie. engine and ACC power). You can't turn the engine off and go straight to ACC- like with a traditional keyed ignition system.
So, I turned the engine off and then immediately wanted to listen to the radio - so pushed the "START" button to get ACC power on. However, both Mobius shut down and failed to restart. I've definitely performed the same procedure with older firmware versions and not had this problem. The Mobius are powered from ACC power.
