Tanckom
- May 1, 2016
- Germany
So, the previous post has now 20 pictures, which takes hell long to load, and i get closer to it, so for those who read the previous post, keep continuing reading here.
UPDATE 26.05.2016
--> after new trys, yes, my sleep was too short to be registered
Conclusion:
After another test, i found out, that only the three first values of
t ia2 -adj awb 0 0 0 0 0 0
are doing some changes.
FIRST VALUE:
Currently, i think the first value is some color value. However it changes between green/yellow/orange.
SECOND VALUE AND THIRD VALUE:
Maybe they are some levels correction? Because directly after using 5000 values, they change from yellow to clear images.
UPDATE 27.05.2016
All test have been done in dark room with artifical lights.
Test 8:
Scaling the first value everytime +2000 up, and doing at the same number for the first value +2000 for the second value.
Since 4000 3000 looked best, i tried another round with lower differences:
And looks like the first value for this environment is good between 4000 and 4500.
Now looking at the best second value:
I think that: t ia2 -adj awb 4250 3500 0 0 0 0 looks best. Info, my wall is not white, but bright-beige.
Test 8 Conclusion:
First value between 4000-5000 looks the clearest. All other value are either blueish, or green/orange yellow.
Second Value between 2500-5000 looks the clearest. All other value are either blueish, or green/orange yellow.
TEST 9:
Did several previous tests, where second value was 0, however didnt see any changes.
Setting second value to 4000 doesnt bring any changements too.
Here the results.
Test 9 Conclusion:
Only the first two values seem to have an impact on white balance
USED SCRIPT, DOWNLOAD BELOW. (TAKES PICTURES AT BOOT)
UPDATE 26.05.2016
Conclusion:
FIRST VALUE:
UPDATE 27.05.2016
Test 8:
Test 8 Conclusion:
TEST 9:
Here the results.
Test 9 Conclusion:
