VIIVIIIXIII
- Apr 25, 2013
- Canada
- ITB-100HD, SG9665GC, Mobius B & C2, T1, Z970WD
Updated Mini 0807 (review update!)
Thanks to Skyhigh Electronics for supplying this unit for review.
Review of the original Mini 0807 here:
https://dashcamtalk.com/forum/threa...x322-gps-dual-sd-card-obd-parking-mode.19890/
Mini 0807 update:
I was contacted by Joy @ Skyhigh Global, and was advised that there have been some updates to the Mini 0807. The main updates to the Mini 0807 include:
1) With the original Mini 0807, I had issues with an out of focus image after leaving the car parked outside (in the summer) for an extended period of time. The manufacturer claims that the focus issues have been fixed due to revised hardware (ie. metal lens holder). See the sample clips and screenshots below re: video quality of the new unit. It appears to be very sharp and I have no issues with the focus. Note: it’s almost winter now and the weather is not as hot as it was when I did my original review -- so take this information with a grain of salt.
2) The Mini 0807 now features a temperature sensor IC, allowing for “Smart Over Temperature Protection”. This sensor monitors the camera's internal temperature and will disable recording if the internal temperature is above the set limit to prevent damage to the unit. The user can preset the over temperature protection within the menu using the “Senior Setting”. Temperature can be preset from 60°C-85°C (140F-185F), default is 85°C(185F). Note: Operating temperature is rated for -10°C to 60°C.
This Mini 0807 uses a super capacitor. Parking mode can be activated if the unit receives 12V power via the OBD port (OBD cable is included). The unit also monitors battery voltage and will cut power to the unit if the car’s battery drops to below a certain voltage. The user can preset the power off voltage point within the menu using the “Senior Setting”. Temperature can be preset from 11.8V to 12.2V, default is 11.8V.
IMPORTANT: These changes are both hardware upgrades to the updated Mini 0807. Updating the firmware on the original Mini 0807 will not yield improvements.
WARNING: DO NOT UPDATE the firmware on your original Mini 0807, as it can brick your camera. Cameras pre-installed with firmware 20160621 or newer are the updated Mini 0807.
More about this topic here: https://dashcamtalk.com/forum/threads/mini0807-over-temperature-protection-for-parking-guard.21182/
Screenshots:
Sample Clips:
Unboxing:
The box of the updated Mini 0807 is different from the one I had previously reviewed. Additionally, there is a slip of paper that explains “Smart Over Temperature Protection” which did not come with the original Mini 0807. The accessories included in the box are the same for both units.
The only way tell if you have the original Mini 0807 or the updated Mini 0807 is by checking the pre-installed firmware. Units with firmware 20160621 or newer are the updated Mini 0807. The new and old Mini 0807 units have identical external housing.
NEW available optional accessories: hardwire kit + CPL filter
https://dashcamtalk.com/forum/threads/mini0807-cpl-filter-obd-cable-hardwire-kit.21081/
Mini 0807 update:
Screenshots:
Sample Clips:
Unboxing:
