Have you performed any audio quality comparison testing of cameras? I have noticed a big difference E1 Pro vs A229 Pro with E1 Pro not loud enough. Voices sound muffled.That's pretty much what I did with my testing, wasn't that much of a difference. It seemed to filter the harsher frequencies a bit which helped haha
Not going to do scientific sound testing on it now, not worth the trouble if it cleans it up at the expense of loudness which just makes impracticalHave you performed any audio quality comparison testing of cameras? I have noticed a big difference E1 Pro vs A229 Pro with E1 Pro not loud enough. Voices sound muffled.
Same here. No more dropped/skipped frames on the pre-release FW.I got a pre release firmware that has fixed the jumping video issues from the clips I checked.
This should be available to the public in the near future from the information I got.
With this being fixed I don't have any complaints anymore.
The temperatures are rising and I will report if I get any heat related issues. So far everything is good.
www.vantrue.com
I have noticed the E360 is more sensitive to road bumps since its latest FW update. I'll check on the E1 Pro - I did the update last night.Is it just me or did the G sensor get more sensitive?
I already turned it down to 1 (Up/down) and the others on 2.
The G sensor still got triggered several times by potholes.
may I ask if your E1 Pro is being used with the LTE module? If so, this behavior is normal. Regardless of which parking mode is selected — motion detection, impact detection, or others — once the trigger conditions are met, the dashcam will not only start recording but also take a snapshot. The captured photo will then be uploaded to cloud storage and a push notification will be sent.My parking sensors do seem to trigger the dashcam into taking a picture.
I had this happen with another company as well.
Did anyone else experience this?
I will search for the video and report it to Vantrue
I think you misunderstood me.may I ask if your E1 Pro is being used with the LTE module? If so, this behavior is normal. Regardless of which parking mode is selected — motion detection, impact detection, or others — once the trigger conditions are met, the dashcam will not only start recording but also take a snapshot. The captured photo will then be uploaded to cloud storage and a push notification will be sent.
sorry for the misunderstanding, we have received the videos. I will let you know after our team check it.I think you misunderstood me.
The sound of my parking sensors does cause the dashcam to take a snapshot while it's in normal recording.
This happened several times already and shouldn't happen.
Email with an example will be sent.
After the last firmware update on the E1 Pro, I also experience a too sensitive g sensor when driving over speed bumps or pot holes, with all settings of directions set to 1.Is it just me or did the G sensor get more sensitive?
Just like with the E1 Pro, after the latest firmware update I also experience a too sensitive g sensor with the E360 when driving over speed bumps or pot holes, with all settings of directions set to 1.I have noticed the E360 is more sensitive to road bumps since its latest FW update.
