Vantrue E360 ACE review and unboxing
was 12.2v /always on , until now it easily managed 14-18 hrs overnight when parked
It wouldn't hurt to clarify a couple of questions:
1. What parking mode do you use?
2. What capacity battery is installed in your car?
i use the low bit rate recording when parked, would need to check the battery specs
i wiggled the connection into the screen mount and its been working today, i will report back if further concerns
Loose connections are a potential issue in many dashcam systems.
I assume you're referring to the magnetic connection between the E360 and the GPS mount? Mine allows a tiny bit of movement, and I can see on videos that the camera moves relative to the dashboard.
yes , a snap /click type would be prefered
couple more clips added , apology's the weather has been dull and rainy here, i was hoping to add something sooner
i must say , i hoped for better detail on the front cam , i think it would struggle to i.d a driver or registration plate most of the time , yet the interior view i can read the label on my wife's bag!
a suggestion for vantrue
would it be possible on a firmware update to have more parking options? say full recording when parked for a set time , then change over impact or motion sensor , or a clock based setting so full recording until midnight then switch to a low bit rate or something?
and a question- is the motion activation only via the front cam?
There's a sub-option in the parking mode menu to select which camera or cameras are used for motion detection
would you be so kind as to explain where , i have motion activation set and struggling to find this menu
thank you
thank you
I'll have a look when I'm back at home tonight
had a near miss today with a oncoming driver not watching the road , decided to replay it and have a look
bit disappointed can barely tell what brand of car it is , no way to i.d the driver or licence plate at all
what do you all think?
I agree with @EricSan that the fisheye is good for wide coverage of what is happening around your car, but not for resolving details. If there had been a collision here, your camera would have shown that you were not at fault.
Driving between trees into the sun with glare off the dashboard and windscreen is also a very challenging scenario for many cameras. A high-bitrate standard lens dashcam with a CPL filter would be much better in such a situation.
Can you read the licence plate on the rear camera?
I still run this (fisheye mode) and for now I think I will keep it in the car alongside my current Viofo - it's the perspective of seeing out the side which keeps me from removing the E360...
Paul.
okay well today its dead /not working , power at the supply cables , ground secure , good battery voltage as the car still runs
is there anything i can do /test please
@Jeff_Vantrue
