Julian23
- Nov 16, 2016
- Germany
- Several brands :)
My experience with the Vantrue JS1 over the last several months was very positive, so I was curious to see how their newer JS3 model stacks up as Vantrue offered me to check it out.
This new version is a 3-in-1 device combining a jump starter, an air compressor, and a power bank.
With a massive 3250A peak current, the JS3 is rated for up to 3.8L diesel engines and 8.0L gas engines. This means the widely used 3.0L diesels here in Europe will be absolutely no problem for this unit to handle.
Key Specifications
Jump Starter
Packaging and Carrying Case
The packaging is standard Vantrue. It is clean and informative.
The back provides all the technical specifications.
Opening the cardboard box reveals a very nice semi-hard carrying case. It has a small loop which can be used to carry it.
The case feels durable and is branded with the Vantrue Power logo.
Inside, everything is neatly organized. The top half holds the accessories in a mesh pocket, while the bottom half cradles the JS3 unit.
A closer look at the top compartment shows the jumper cables securely stored.
The JS3 fits snugly in its designated spot.
Build Quality and Features
Taking the JS3 out, the build quality feels solid.
The back of the unit lists the regulatory labels and the technical specs.
One of my favorite design choices is the cleverly hidden storage compartment right on the device for the air compressor nozzles.
It is a really clever solution so you do not lose those tiny valve adapters.
One side has both USB ports, the compressor outlet and the connector for the jump starter.
The less often used ports for the compressor and the jump starter are hidden with a flap.
More in the next post. (picture limit)
Key Specifications
Jump Starter
- Peak Current: 3250A
- Compatibility: All 12V vehicles up to 8.0L Gas and up to 3.8L Diesel engines
- Modes: 6 presets (Car, SUV, Motorcycle, Bicycle, Ball, Free mode) with Auto-Stop function
- Supported Units: PSI, KPA, Bar, kg/cm²
- Display Precision: Down to 0.01 Bar increments
- USB-C Port: 65W Power Delivery (In & Out) for fast charging laptops, tablets, and phones
- USB-A Port: Quick Charge 3.0 (QC 3.0)
- Smart LCD: Real-time battery capacity, tire pressure, and live vehicle voltage display (when clamps are connected)
- LED System: White light (Solid, Blink, SOS) and Red light (Warning flash, SOS)
