Vantrue OnDash X4S
Has the over heating issue I've been reading about been addressed?
Has the over heaInstead of lithium battery, this car camera is powered by a super capacitor that resists extreme temperatures from -4°to 176°F (-20°-70°C) and provides more reliability and a longer lifespan, which means without the risk of overheating and exploding to you.ting issue I've been reading about been addressed?
The reasons that you can choose Vantrue X4S WiFi dual dash cam​
  • Lower power consumption and more resistance to heat with upgraded Novatek High-Tech Chip.
5G/2.4G High-frequency WIFI module: Faster connection and download speed from your dash cam to your phone.
  • Front camera, featured with cutting edge OmniVision 8 million ultra-clear photosensitive image processor.
Multi Parking Mode / ETH Ethernet data transmission mode comes with a super anti-interference capability
  • Rear Camera, holding a powerful SONY STARVIS processor.
Independent DSP processor: Dual DSP design provides for faster rear camera processing.
  • 4K+1080P High Resolution will capture license plates easily even in low light environments.
Larger Screen: 3" IPS display screen provides clearer image display quality.
Specification for X4S​
Video Resolution:
4K 2160P @30FPS/1440P@ 60FPS /1080P@120FPS/1440P@30FPS/1080P@ 60FPS
Image Sensor: OmniVision
Storage: 512GB microSD card max
Port: Type-C
Battery & Charging: Super Capacitor
Microphone&Speaker: Built in
Screen: 3 inch
Vantrue X4S Dash Cam Firmware Update​
  • Release time: 2022-09-13 18:50:17
  • Version: VTX4S2D.V49
  • File size: 23.5M
  1. Fixed the update issue with former version.
The Vantrue X4S is one of the easiest and affordable 4k dash cameras on the market. This camera features a 3" IPS screen which makes for navigating the menu very easy even for people like myself with aging eyes. The menu is straight forward and intuitive and the X4S is also able to be controlled by the Vantrue dash cam app via wifi. With the app you can also download and view footage. Alternatively, you can connect the camera to a desktop computer and use the Vantrue viewer where you can view both channels at once as well as view speed and location if you have the optional GPS mount.
The front camera features a quick F1.7 lens and films in full 4K while the rear is a F2.0 camera shooting at full HD 1920X1080, both provide a 131 degree FOV.
For coverage after hours, the X4S can go into parking mode when the ignition is turned off. For this to activate though you will either need to provide power by either purchasing the hardwire kit ( available from Vantrue) or using a seperate power supply like a portable dash camera battery system. There are 3 modes:
1. Motion - The camera will start recording at a lower resolution when motion is detected by the cameras, if the G-sensors detect an impact during this time, the camera will revert to its original quality.
2. G-Sensor - The camera will start recording when it detects an impact. You can specify the sensitivity in the menu.
3. Time Lapse - The camera will record in a lower frame rate to save space and will revert to full quality if an impact is sensed.
See what Vantrue X4S impressed Everyday Review
Vantrue X4S Duo Wi-Fi Dash Camera Review from EverydayReviews​
X4S installation & recording performance shared by Vantrue customer👍
-Can #VantrueX4S take a picture if there is something fun on the road?
-YES! Both the camera and the Vantrue Cam APP can take a picture.
On the dash cam, we can press the power button to get the picture snapped.
An insightful Vantrue X4S Duo 4K WiFi dash cam reviewed by Brian. How the camera works and if it is a good choice for you.
Check out here and see more details:
- It is X4S a 2 piece unit?They were telling me it was going to be one unit like the duel setup like the N2S but with Wi-Fi.
- Nope, it is front camera only, but we also add a rear camera as an option. Someone doesn't like dual-mode. If you add the rear camera, then it is front and rear dash cam with WIFI.
