Julian23
- Nov 16, 2016
- Germany
- Several brands :)
Vantrue is currently releasing unit after unit. Next up is the new S1 Pro Max, a dual-channel 4K front and rear STARVIS 2 dashcam. Vantrue sent me the S1 Pro Max to check out. Many thanks again to the Vantrue team! This model upgrades the 2-year-old S1 Pro (which was 2.5K+1080p) to dual 4K, putting it on par with the latest dual-4K dashcams from other brands, and it adds AI safety features.
Features:
The S1 Pro Max supports microSD cards up to 1 TB and is also compatible with Vantrue’s optional LTE module, LT01, for cloud features (live view, alerts, etc.).
Like other Vantrue cams, the S1 Pro Max uses a supercapacitor (not a battery), so it can safely survive heat and provides a few seconds of runtime after power is cut.
The S1 Pro Max has a 155° wide viewing angle for both the front and rear cameras.
Unboxing the S1 Pro Max, you’ll find a high-quality presentation box.
Opening the box will greet you with the manual and also with information that the warranty can be extended to 18 months.
Inside, the main 4K dashcam unit, a waterproof rear camera module (new RC11), mounting accessories, and documentation are all neatly organized in cardboard cutouts. Everything feels solidly protected.
Accessories include: spare adhesives for the front and rear units, a single hinge mount for the rear camera, a power supply, a plastic pry tool, and quick-start guides.
The new power supply with 3A output for the camera.
Single hinge mount for the rear camera and spare sticky pad
The rear RC11 camera has a fully-waterproof design. Its mount uses two metal side plates with hinges, allowing you to tighten screws to hold the angle. Vantrue also includes an alternate single-plate hinge mount as well. These metal mounts, along with adhesive tape, give you flexibility to mount the rear cam on a horizontal or vertical surface. You can also screw it down for extra security.
Because the rear cam is sealed, it has no open cooling vents. Its backplate is metal and does get hot when recording. The camera has a built-in 40 cm USB-C pigtail (to stay waterproof) that connects to the 20 ft extension cable to reach the front unit.
Currently, there’s no CPL filter available for the rear camera.
More in the next post!
Features:
- Dual 4K HDR recording (front & rear)
- Dual Sony STARVIS 2 IMX678 sensors
- Vantrue Intelligence for smarter driving (AI-based collision, lane, blind-spot alerts)
- Exclusive PlatePix™ Technology
- Compatible with LTE Module (LT01)
- IP67 Water-resistance for the rear camera
- 5 GHz high-speed WiFi
- Smart voice control
- 24/7 parking mode
- Supports up to 1 TB microSD
- Front only: 3840×2160P (4K) @30 FPS
- Front + Rear: 3840×2160P + 3840×2160P @30 FPS
