- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
We just got these in and have to say, if you want the Mercedes of BDP (battery discharge prevention) hard wire kits, this is it!
-Easy Digital Display (no confusing dip switches) with finer granularity of control
-Higher Voltage cut-0ff options than others out there
-High Temperature cut-off (wow)
-Timer you can easily switch on/off
-30 second timer before the cut-off occurs to ignore temporary dips in power (Playing with the Radio etc)
-Easy switch to change between AAC/Switched Driving Mode and BAT/Un-swtiched Parking Mode
User Manual:
https://www.dropbox.com/s/m0tqkebgpheccuo/Vicovation-Power-Plus-User-Manual-English.pdf?dl=0
I recently put one on the bench and a did a complete detailed walk through. Here you go:
Now available via OCD Tronic
& OCD Tronic Amazon.com
http://www.vicovation.com/product.asp?IDno=55&lang=eng
VICO-POWER PLUS
Vico Power-PLUS: Your Smart Car-Battery Power Management Device!
Power-PLUS is a power management device connecting to car battery which working with Dash Cam/Blackbox DVR, continuously providing power after engine-off while parking, and monitoring your battery status. Power-PLUS detects car battery status to cut-off power to prevent car battery from being drained out (discharged).
Vico-Power Plus: Your Smart Car-Battery Power Management Device!
Power Plus is a power safety device which connects to car battery to work with Dash Cam/Black Box, continuously providing power after engine-off while parking. Together working with Vico Smart Parking Mode function, your Dash Cam can have motion-detection recording after you left your car, for having full protection of your car. Power Plus will auto-detect your battery status to cut-off power supply to prevent car battery from being drained out.
Power Plus provides multiple protection to have better safety coverage, including:
1. Low Voltage protection
2. Over Temperature protection
3. Timer protection
4. Over Current/Surge protection
Power-PLUS will periodically auto-detect your battery voltage status, to cut-off the power if the voltage drops below the configured value (11.6/11.8/12.0/12.2/12.4V/12.6 or 23.2/23.4/23.6/23.8/24/24.2/24.4/24.6V) to prevent car battery becoming excessively discharged.
During Summer daytime, inner car temperature raise extremely high if you left your car outside with direct sunlight. Over temperature operation might damage your dash cam. Power-PLUS built-in thermo sensor will cut-off power if temperature exceeded setup value. (Off /50°/55°/60°/65°/70°/75°C) *(Off /122°/131°/140°/149°/158°/167°F)
Timer protection
If you switch into Timer mode, Power-PLUS will cut-off power when time out, based on your setup schedule (2/6/12/24/48/72hrs).
Power-PLUS will detect abnormal over current status and cut-off power to prevent any damage on dash cam device. Additionally, Power-PLUS built in with an extra fuse box (2A), to have extra protection if anything goes wrong as incorrect installing or short circuit.
The Most Perfect Power Device for Smart Parking Mode!
Vicovation Marcus series Dash Cam built in Smart Parking Mode function, providing full protection / continuous recording when car parked. Power-PLUS is the best companion to enable this continuous monitoring function.
Built-in Digital Display/Backlight LED, easier to monitor/control
Backlight LED enables users to have clear display of car-battery voltage monitoring and setup control, even at night. It’s easier to setup configuration with 3 handy control buttons with clear LED friendly display.
Compatible with all kinds of Dash Cam/Car Cam!
Power-PLUS is 100% compatible with all Vicovation production, and also it’s compatible with other car cam/black box DVR which equipped standard cigar charger power supply. Please Note: Other Dash Cam/Blackbox DVR may not include the Smart Pakring Mode function.
Multi Input Power Type, DC12V/24V all in one
No matter your car is running DC12V or 24V battery, Power-PLUS will auto-detect the voltage input to display different programmable menu setting. It’s automatic.
Multi-Swtich to Select Normal mode and Timer mode
Normal mode provides low voltage and over temperature protection at the same time. Timer mode provides original both low voltage and over temperature, also additional timer cut-off when schedule time out. There is a switch on the right side of Power-PLUS for you to switch under different condition.
Programmable Setting, fitting your car environment
Users can select it’s own suitable parameter in different cut-off voltage, temperature, and time. It’s all clearly displayed in comprehensive menu and friendly user interface.
Main Switch to Select Activate/Bypass for Different Parking Environment/Situation
You may select Power-PLUS power output depending on different parking environment/situation. For example, you may switch to “Bypass” while parking at home garage for saving memory space and car-battery power. And switch to “Activate” while parking outside/unfamiliar place, co-working with Smart Parking mode for parking surveillance.
Switch to Activate: Power-PLUS provides power output to Dash Cam while engine on and also engine off, simultaneously with cut-off protection based on low-voltage/timer/over-temperature.
Switch to Bypass: Power-PLUs provide power output to Dash Cam ONLY when engine on (ACC on). When engine off (ACC off), Power-PLUS provides NO power to Dash Cam.
User Manual:
![yaRBuNP.png](/forum/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FyaRBuNP.png&hash=489a6eabef5b77b6c778c317316de268)
VICO-POWER PLUS
3. Timer protection
![Vico_20155702014.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155702014.jpg&hash=f084412af14fbdac9e53b0d214ea97e5)
![Vico_20155703319.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155703319.jpg&hash=ea1f77370ef19eb8aacd9acb992d779a)
![Vico_20155703852.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155703852.jpg&hash=6193fe61c11f63e8b991dea73344fcf8)
![Vico_20155733147.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155733147.jpg&hash=02a891bd779a10b04db54b0a3056170d)
![Vico_20155122737.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155122737.jpg&hash=60ba8b584a895e580d7ac944d9a108bb)
![Vico_20155733455.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155733455.jpg&hash=8fe1c69bc284872f2ed485f439f01a65)
![Vico_20155735332.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_20155735332.jpg&hash=bf55ca8aebdf9da75bd055e8ce72a7c5)
![Vico_2015574115.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_2015574115.jpg&hash=59e98d90091433b9f600983d98ce71b1)
![Vico_201551235720.jpg](/forum/proxy.php?image=http%3A%2F%2Fwww.vicovation.com%2Fuploads%2FVico_201551235720.jpg&hash=e2a0dfb13774d0db86ef76a3c39dfe17)
