WashingtonDash
- Aug 1, 2018
Installed the vico power plus with the Blackvue DR900S-2CH and have tested every combination of voltage, timer and even heat, and the unit will not power down. I can only put it on Bypass and turn of the ignition and it will shut down. Any of the power off features will not shut the dashcam down. Asking the question on the Amazon page if this unit could be defective if it doesn't shut down, the retailer responded as if it was my fault:
VicoVation Vico-Power PLUS Battery Discharge Prevention (BDP) Device for Parking Mode
Rephrase the question, unit will not power down on timer, voltage or heat, is it defective?
No other reports of that ever. Double check power sources being used, ground/wiring, dip switch positions, built in fuse. You have a one year warranty from the seller you purchased it from if you confirm you have some rare defect where the power stays constant.
