petrlustich
Please explain. What do you mean with „everything can be done“? Did you modify the firmware and the issues in the dark are gone?
Yes - I changed the firmware and everything was readable.Please explain. What do you mean with „everything can be done“?
I continue to edit the firmware!
Then I will ride day - night.
I would like VIOFO to fix the firmware, there you just need to coordinate the exposure and shutter speeds of the camera.
The default exposure is very long, so everything doubles, smears.
make sure you have it set to 60Hz and not 50HzI have the same issues. When driving at night and fps is set to 60, i have massive flashes in the video. When setting fps to 30, everything is ok.
When driving at day everything looks great, in 60fps and 30fps.
Here are 2 example videos, weather was really bad.
60fps:
30fps:
Is there a possibility to do a firmware downgrade? Where can I download the previous firmware?
50Hz is default
the issue is your running 50Hz then at 60FPSGood suggestion, but actually, the electrical frequency in Germany is 50Hz, not 60Hz like here in the USA. Aside from that there seems to be something else going on here with this issue that has nothing to do with electrical frequency. It happned to me too. Personally, I thought at first this problem was PMW (pulse width modulation) but that theory proved wrong too. Hopefully, a firmware update can fix it.
yeah the first is 60fps HDR on and the second is 30 fps HDR off
mine is not as bad as yours is though
video 60fps with HDR off
there is some small ripple in the videoPersonally, I experience the low light banded flashing issue with the camera set to 60 fps @ 60Hz, not 50Hz, and with HDR off. I'm not seeing the flashing issue in your video.
The double exposure HDR problem is a different issue. I'm not quite sure we're talking about the same thing.,
this screen shot HDR was enabledI've watched your video several times and I do not see the issue @Tyestick first brought to our attentions in this video.
50Hz is default
I will try it out and set it to 60Hz. But I cant imagine, that this will help with the flickering in the darkness. Btw, I do not use HDR.
What kind of lightbulb is that? Also, is your power frequency something other than 60 Hz? Try and take a picture of the moon, and see if that flickers too.Choice in the menu of the DVR and that's what we get !!
In my country, 50 hertz is used.
Do not use 60 frames, there is an error, every second frame is duplicated.
VIOFO didn't fix the problem!
I tried it. Flickering is not gone when using 60Hz and 60fps. While using 30fps everything is fine. What I really dont understand: why does the flickering and the black stripe only occur at night? During daylight the picture is superb!
