Ok. Today i have planed to instal the 119sv2 in my car. i have buy it from banggood.
the cam came to me 4 days ago.
today i was sitting in the tv room and watched tv.
then i hear a loud "POP" sound from my left side. i was looking what it could be.
the a119sv2 in the original box was on a board on my wall.
so i opened the box and it smells like electrical burning.
the camera was smelling to, so i opened the cam because i was afraid of fire.
inside i see a brown liquid and one of the supercaps was open. i have clean it up with some qtipps and toiletpaper.
i have never used the camera, even all the 3m stickers are untouched.
today i have contacted banggood to send me a new camera or give my money back.
do somebody see something before on an absolutely unused camera?
Those capacitors are poor quality. Any time a capacitor bulges and leaks its either under rated for power flow (6volts for 12volt circuit) or very old or counterfeit low quality copy (very common in China). That is a VIOFO manufacturing warantee issue create a Service Ticket and get a new Dashcam. If they won't do it let me know instantly.
From my A119S Troubleshooting Guide ...
Part E - Replace both Capacitors (
STOP if had no experience solding)
1) with Dashcam back cover open gently detach Lens/Sensor Ribbon cable (
less chance of scratching Lens)
2) remove 4 screws holding main circuit board to plastic frame.
3) gently lift top edge (sensor end) of circuit board to access reverse side of Capacitor solder joints.
4) draw diagram showing polarity of capacitors.
5) using 25 to 40watt soldering iron heat bottom joint then pull cap from opposite side to remove each wire. (
experience needed)
6) trim new trim new
KamCap 3.3F 2.7V SuperCapacitor -or-
Nichicon 3.3F 2.7V SuperCapacitor connector leads to same length as originals. (depending on cap thickness for bending over)
7) carefully solder each new capacitor, verify polarity position twice (
warning: else caps explode)
8) verify new capacitors bend into flat position.
9) reassemble Dashcam
10) Test using Bare Bones setup in
Part A
