VIOFO A129 non-IR 1080p Modified Firmware MODs Archive
Created new A129Duo - STABLE versions 2Uj , 4Uj , See post #1 of this thread for details and ChangeLog.
These MODs are based on newest official VIOFO FW v1.50 , increased Rear camera Bit rate.
Higher Bitrate MODs improve image detail and increase MP4 video clip size.
FWA129_MOD-2Uj_v1.50+22F+22RMbs+Sharp123+Edge132+DCTeam.bin
Download 2Uj > https://drive.google.com/open?id=19PN1EeF8h88sOxyNwz7QzS8w57zDPIIQ
FWA129_MOD-4Uj_v1.50+24F+20RMbs+Sharp123+Edge132+DCTeam.bin
Download 4Uj > https://drive.google.com/open?id=1vaWw127YmcPzLU7VJBLwqeD77TxfOUQn
43773
Viofo A129 Duo Dash Cam Review > https://viofo-a129-duo-dash-cam-review.blogspot.com
DCTeam - CEO/CEH/CDO/DRD/DSP/IQE/PDU/SFC/LLS
YouTube Channel: https://www.youtube.com/user/BCHobbyist
Hi it is possible adding mic on at parkingmod and mic off in driving mod automaticly
Probably more hassle than it’s worth, it’s only a double button press anyway and you don’t even need to be able to see the unit to do it.
Sent from my iPad using Tapatalk
@BCHobbyist, great work. I'm going to try this out soon.
Can you explain the numbers in the slashes in "override BitRate Menu to increase ... to 22/22/8/7Mbs?" Does it mean Bit Rate Low/Bit Rate High/BR Low Wifi/BR High Wifi + APP?
Also, how difficult is it to edit the menus? Can you add/expand options in the menus? For example, under Bitrate, can you have Low, High, Super High?
I figure you're just hex editing and not decompiling or building the firmware from the SDK?
Just noticed this on the 4Uj mod from this evening - there's some artifacts on the rear cam...
RAW FILE
YT:
artifacts are when there isn't enough lighting, would expect the original firmware would probably doing the same in the same situation
If you refer to the noise that is visible at 0:38, I confirm - it is present on every firmware that I used - official and MODs
The back window gets damp - my car isn't airtight enough. But I hadn't seen that "square blockiness" before, yes at 38 and around 48-55.
Now I know what you mean. To me, it looks like poor noise reduction algorithm.
Sent from my SM-G935F using Tapatalk
The way pictures quality is damaged is actually threw noise reduction (denoise). In photography you want slight noise and slight denoise. The more noise reduction is applied to image the worst picture quality it gets.
It seems noise reduction is factory standard but as we increased picture quality the lessened the effect of denoise on the noise which is apparent in poor lighting conditions. Just a theory. lol
Hello guys, do I understand it correctly the A129 Duo hasn't buffered parking mode? Do you thing it will be added to the firmware? Is it possible? This is the only reason I hesitate to buy this awsome cam. If I don't buy it, I will buy the DOD RS500S because have not found better camara with such a video quality.
not supported by the chipset, keep in mind buffered parking mode exists to improve the poor results of motion detect which is not reliable otherwise
Ok, so when someone bumps into my car, the only possibility to record it is the motion detection. But when the motion detection fails I have no evidence the car bumped into my car. This is why I want the buffered parking mode.
that's why not to use motion detect
Why do you use this camera when it has no buffered parking mode and the motion detection is unreliable? You either don't need evidence for police or insurance company or there is no other camera with such a quality and features and offering the buffered parking mode. What is the reason?
I use either timelapse or low bitrate continuous recording when parked, so I'm not relying on motion detection at all.
