VIOFO A329 2CH - Testing / Review - RCG
24 fps almost eliminates the flickering of the vehicle's LED lights, day or night.
@viofo @VIOFO-Support
Instead of (front) 60 fps and (rear) 30 fps, you can try software that supports 24 fps or 25 fps on the rear camera and 50 fps on the front camera.
24 / 25 FPS would be interesting to experiment with. Where I live, many of the traffic lights and a lot of the cars have that flickering. It is annoying to watch on the video but does not distract our judicial system from using a video for a trial. That FPS is a bit slow for highway or fast moving traffic would it could work great for UBER and taxi drivers in metropolitan areas. Not sure though that VIOFO would go to the effort of fine tuning the software for 24 / 25 FPS. Would be interesting though.
24 FPS does not necessarily mean 'Fake 4K'. Cinematic mode and,or video motion can determine the FPS in 4K.
30 FPS or 60 FPS provides less strobing and choppiness in 4K, but you can still do 4K in 24 FPS for average motion.
This is correct with the 23.97fps'ing we talking about here
24fps = Fake 4K
30fps = Minimum True 4K
Are you trying to get A329 on this list? ☕
Well, you are wrong in your assessment of the issue.
With what you wrote above, are you trying to say that the A139 Pro offers fake 4K with 24fps when using 3 cameras?
A completely unfortunate statement.
Unfortunately, your big speeches from the beginning are just prolonging the topic.
The current a329 has front camera 4k 60 fps and rear camera 2k 30 fps. My suggestion is to add 4k 50 fps for the front camera and 2k 24 fps or 25 fps for the rear camera to the resolution settings of a camera of this capacity.
This is not a fraud, it may mean testing, trying, checking efficiency, reducing temperature, expanding data space, perhaps pleasing some users in the image.
Not me or you. When a new user watches the images, they may consider these light flickers as a problem.
One should not act selfishly.
The SSD disk is just super, but there are also errors!!
The firmware from the SSD is not updated, the firmware file is ignored, the recording starts immediately!!
If you watch the video from the SSD, then 329 freezes and no button works, only removing the power helps!!
From the flash card, everything is great!!
The latest firmware is VIOFO_A329_V1.0_241126
When changing the HDR mode, the WiFi broadcast in the application freezes!!
Interesting the SSD is exFAT so it should work cos microSD in exFAT also works for firmware updates
Not support firmware upgrade via external SSD
If there is no reading from SSD, then it makes no sense to use this device, because how can you show the video to the police?
Updating firmware via an external SSD and watching video files on an external SSD are not the same thing.
This is called reading files!!
F
Bit rate : 65.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS(30.000 FPS)
R
Bit rate : 27.0 Mb/s
Frame rate : 30.000 FPS
I picked three different 1-minute front and rear camera video segments from a recent sunny day drive to put together as a 3-minute videos for uploading to YouTube.
  • Firmware:
    • v1.0_241126
  • Video Storage
    • 1TB SanDisk SSD
  • Front:
    • 4K 60fps
    • HDR Off
    • CPL Installed
  • Rear:
    • 2K 30fps
    • HDR Off
    • No CPL
Can the A229 Duo rear camera be compatible with the A329 because it uses the same cable?
That was the first thing I checked when my A329 was delivered.
When I connected the A229 Duo rear camera it played this sound in my head. lol
Back in July when I first received the prototype A329 to test, I confirmed with VIOFO that the A229 Duo rear camera cable is the same cable as the A329 rear camera cable. I used that to my advantage so I could move the A329 between two different cars.
July????
I'm guessing you're questioning my statement of July for the A329. Yes, I received a prototype A329 to begin early testing of the A329 in July 2024.
I don't know if the A229 Duo's rear camera is compatible with the A329. Since the A329's rear camera is based on the Sony STARVIS 2 IMX675 and the A229 Duo's rear camera is based on the Sony STARVIS IMX335 image sensor, I would venture to guess there might be some differences in how the rear camera is monitored/controlled. That's a question for @viofo
Hahaha, not at all, I just didn't realise it was out there so far back, even Chuck only got one to play with late October time.
How's the drone flying going BTW? You got the new Air 3 S?
lol
After the A229 Pro I specifically told Viofo I'm no longer willing to test & review PRE-PRODUCTION units.
And I'm only willing to test & review fully finished RETAIL / PRODUCTION versions, (same as sold to paying customers).
I simply do not have the intelligence / equipment to offer meaningful feedback.
