VIOFO A329 Testing & Review Europe
Julian23
Germany
Several brands :)
I know I’m a little late to the A329 party, but here I am!
I just got my hands on the A329 yesterday, and I’m ready to start my testing. I’ll be sharing my findings and experiences along the way to give you all a closer look at what this dashcam can do.
First up, I’ll be adding a few pictures to show what’s included when you order one, along with comparison shots next to the A229 Pro for a better sense of its design and build.
Video footage will be coming within the next few days, so you’ll get to see how it performs on the roads in Europe or to be precise in Germany.
The A229 Pro already did a great job of catching plates even at night. From what I saw here on the forum the A329 should be even a little bit better.
First of here are some pictures of the included accessories.
The USB C cable that was included with the A229 Pro has now been changed to a much thinner Coax cable. Similar to the A139/A139 Pro.
This will make installing and hiding the cable easier again.
I will test the included 12V Charger for its output. The results will be here soon.
Optional Rear CPL Filter.
Optional Remote Control with configurable buttons.
Here is a direct comparison with the A229 Pro.
On the left side is the A329 and on the right the A229 Pro.
A little bit different front design.
Much different design on both sides with way more vents.
The A329 even has 3 vents near the lens.
Yesterday there was a discussion about using small USB type C card readers to move the heat out of the camera.
I had doubts about the performance of these cheap card readers.
Here are my results with writing speed and power consumption.
Recording when measuring the power was done at 1ch, 4k30fps. HDR on, Wifi off.
I used a new Samsung 256GB Pro Plus micro SD card.
Read and write speeds when used with a good card reader: (I did 3 runs and every run was similar)
Read and write speeds when used with the cheap USB C card reader directly into the mainboard of my PC:
Read and write speeds when used with another cheap USB C card reader directly into the mainboard of my PC:
This cheap one has USB A and C. I also tested the USB A side with the following speeds:
Here is the power consumption when using the SD card internally. Like any normal dashcam.
Here is the power consumption when using the card reader with the USB C port of the dashcam.
The min, max, and average values can be seen at the bottom.
There is obviously a difference with the card reader using about 0,42W more power.
Knowing that the A329 writes about 65MB/s I wouldn't recommend doing this with cheap card readers if you want the camera to run reliable.
@Agie
@Panzer Platform
Since I don't have a fancy thermal camera we need to wait for @Panzer Platform to see thermal results.
These results are all based on my cheap card readers. Results may vary with other higher quality readers.
This is meant as a PSA to NOT buy cheap card readers.
Here is the power consumption of first using the SD card internally.
Here is the power consumption when using the card reader with the dashcam.
Knowing that the A329 writes about 65MB/s I wouldn't recommend doing this if you want the camera to run reliable.
@Agie
@Panzer Platform
Looks like we were correct Julian, but boy oh boy what a delta in performance between the decent brand-name microSD card reader and the cheap no-name one.
The results are just what I expected and feared. You get what you pay. In this case not much.
Maybe the higher quality readers can achieve a better performance.
At least now this is properly documented with numbers to prove it.
Remember that the camera writes at 65Mbps, not 65MBps (bits, not bytes), so the 20MB/s reader may still be OK for the A329
It might be interesting to measure the power consumption of just the card reader, if you have a suitable USB power meter, then we can calculate the power consumption of just the camera, if the camera uses less power internally when using the card reader than it should operate in higher temperatures, even if the total is higher.
I assume your power readings are with the fast reader, does the cheap reader work and give different readings?
Do you mean like this?
Yes, something like that, a very useful device for checking power consumption of USB devices, and also for measuring how much power goes into and comes out of USB batteries.
I'm gonna double check it this evening.
Sure, I can check the consumption of the reader itself.
Yes, it was with the faster one. I can try that too.
Here is the result of the power draw from the card reader when in use.
This is more or less the exact difference when using the USB port compared to the SD slot of the A329.
For parking mode in hot places, 0.4 W for the card reader is much better than the 2.3 W of an SSD. Presumably using a memory stick would give a similar result, although you can then get larger capacities.
Even if you are not in a hot place, it is not too bad unless you are trying to achieve 24/7 parking mode.
However, these figures suggest that it doesn't reduce the power consumption internal to the camera, so the camera isn't going to run any cooler... unless you measure coolness based on the temperature of the microSD card slot... presumably the power use has moved from there to the USB-C port controller.
So this might help in high temperatures, but only if the memory card is the problem and is better cooled when it is in the card reader than when it is in the camera, which may be true, but I doubt that it makes much difference, unless maybe you run an extension cable away from the heat near the roof and down to the coolness of the floor area.
Might do better to implement a 15 fps low bitrate parking mode, that would both reduce heat and power consumption!
You ask and you shall receive.
I tested a normal USB 3.0 Stick when writing.
See the results below.
While I was at it I also tested a 2,5" external HDD. (before anyone asks for it)
As expected much more since it's mechanical.
It's a very good question when the increased power consumption creates more heat by the power draw than it reduces with the memory being external.
Looking at Panzer’s thermal images, it appears that plugging in a USB cable sucks out more heat, by acting as a heat sink, than gets generated, so overall, a USB stick, maybe on a cable, will help in high temperatures, and looks a better option than an SSD, especially for parking mode.
A229 Pro has never been installed in a car?
It was installed since December 2023.
To make room for the A329, I slightly changed the position.
Since I had to remove it and replace the 3m tape, I took this opportunity to make side by side pictures.
Currently both cameras, front and rear are installed side by side.
Here are some screenshots from a drive 2 hours ago. I tried to pick the same spot and the best frame for each camera.
These are just random cars from today and not cherry picked clips that were collected for 2 weeks to get the best result.
The A329 has a little disadvantage since it is to the right of the A229 Pro.
Both cameras with the following settings: 4k30, HDR on, CPL on, highest bitrate.
The images are not edited, except for the partial plate blurring to comply with strict German privacy laws.
Some screenshots with daylight.
Cameras with the following settings:
-A329: front: 4k60, HDR off, CPL on, highest bitrate. Rear camera without CPL, HDR on. Firmware: V1.0_241009
-A229 Pro: front: 4k30, HDR off, CPL on, highest bitrate. Rear camera without CPL, HDR on Firmware: V1.3_240612
While installing the dashcam and checking for the orientation, I plugged in the included charger.
Somehow the pin on the top got pushed inside.
I had to use a small screwdriver and slide it around the edge to get it to come out.
I tried it again if it would get stuck again and it did.
This shouldn't happen.
@viofo, @VIOFO-Support would you please check if this is just my unit?
Here is another picture of the charger when it's plugged in.
It has a nice blue ambient light. It's not too bright to be annoying.
The rear camera also has a small white LED that is illuminated when the camera is on.
It's not too bright or in any way annoying at night.
Nice work.
1.) Can you add the firmware version of each camera?
2.) Just to confirm & verify is the A229 Pro Front camera operating with 60 Mbps, or 36 Mbps, (do you have the interior camera connected 3-CH)?
Yikes, mine works OK, maybe you need a replacement.
