Viofo Hardwire Kit / Parking Mode Question
Den-den
Philippines
Yi Dash Cam, Mini 0906
I'm using the Viofo Hardwire Kit and have no problem transitioning from normal drive recording to parking mode when I turn off. The engine.
The questions are:
1. When I'm in parking mode and I entered setup menu to turn off parking mode, is it normal that the cam would then revert to normal high bitrate recording after exiting setup menu?
2. I then entered the setup menu again to turn on low bit rate parking mode and it stayed on normal drive recording. The icon still shows a video icon on the upper left of a car in motion. Does it not default to parking mode when turned on and only the constant 12V line is energized?
3. Is the only way to revert back to parking mode is to switch on the ignition and then switch it back off?
Gooffeyguy
St. Louis
I think after a set amount of time with no GPS change it will go into parking mode, like 3 or 5 minutes.
Sent from my SM-G930V using Tapatalk
D
Den-den
Philippines
I'll have to try this. However, this wouldn't work if you are parked underground with no GPS connection, right?
CaptureYourAction
Retailer
New England
DOD, Dome Technologies, VicoVation, Viofo, GitUp
1) Normal
2) Normal (may re-enter parking mode after 5 minutes, but have not tested)
3) Yes
D
Den-den
Philippines
1) Normal
3) Yes
I tested and confirmed that it will enter parking mode exactly 5 minutes after power on with engine off and GPS active.
