Viofo Hardwire Kits
Dasher286
Minnesota
@VIOFO-Support What's the difference between the HK3-C, HK4 and HK5? They all seem to be USB-C and from the pictures I can find they all have the same outputs. Are they interchangable?
Yes, they are interchangeable. However, the HK3-C has a straight connector, while the HK-4 and HK-5 both have the 90 degree connectors. If you look closely at the HK-4 and HK-5, you will see the connectors differ slightly in shape. I would choose whichever gives your particular install the best appearance.
That's kind of what I assumed. But when you go to buy them, they list them as model-specific. So I wanted to make sire there wasn't any kind if technical difference. Thanks.
